04-01-2015, 02:12 PM #1
- Apr 2015
Makerbot Replicator 1 (dual) lost its mind after attempted firmware upgrade
Hi!
I was trying to upgrade my replicator-1 to a later makerbot firmware version. Tried all the various suggested ways, with desktop or replicator-g, and so on. It always failed. Now, however, the display has two rows of filled-in characters (as opposed to the various push-the-button menu items), and the device cannot be connected to by either desktop or replicator-g.
The windows machine it is hooked to sees the usb connection of the device when connected (and notices it gone when disconnected, or powered off when connected.) Replicator-g sees the comm3-connected-ness of the printer. However, neither can connect to the device to issue commands (including factory-reset, obviously). Power cycles, power disconnects and let sit for a while, and reset button presses are no go. The motors come on, and the backlight for the console is on, so it is getting power.
Since it's a rep-1, makerbot's support doesn't exactly admit it exists. Is there some way I can get my little old printer back, even with the old firmware, or with new?
Thanks!
Charles
05-04-2016, 05:24 PM #2
- May 2016
have the same problem myself anyone help must be a way yo for update over
05-05-2016, 06:23 AM #3
sounds nasty. One reason I've never attempted to update the firmware on my creator are posts like this.
It'd be worth a search as there are quite a few firmware threads, one might have the answer.
05-23-2016, 03:07 PM #4
- May 2016
does this help? (http://bilbycnc.freshdesk.com/suppor...upgrade-failed) a buddy of mine had a similar situation with the black bars instead of the menu items after trying to upgrade and this seemed to do the trick for him.
New member with print issue
