Results 1 to 10 of 11
03-27-2015, 09:36 AM #1
- 41
Prints have started to lean......
Hi All
My prints have started to lean along the Y Axis -any ideas what could be causing this - the bed appears to be moving freely.
Im using a Ordbot Hadron
cheers Graham
03-27-2015, 01:58 PM #2
03-27-2015, 08:02 PM #3
03-27-2015, 11:09 PM #4
- Aug 2014
- Montreal, Quebec
- 576
03-28-2015, 10:57 AM #5
- 462
This might be obvious, but have you checked that the frame is square?
03-28-2015, 11:38 AM #6
- 41
03-28-2015, 04:52 PM #7
03-28-2015, 05:37 PM #8
- 41
The bed and hot plate should move along the axis freely without sticking - i.e should be free to move. I was stating this to try and eliminate movement along the axis as a possible issue.
Ive printed another item and there appears to be a step every 5ish mm along the Y axis which causes the object to lean for taller printed objects.
03-30-2015, 09:01 AM #9
Slow down your printing speed, and/or rotate the object 30 degrees around the Z, and see how that does.
Why? Units that move a lot of mass can have inertia issues at higher speeds, especially with long back-and-forth infill patterns.
04-01-2015, 02:05 PM #10
- 41
