Results 1 to 10 of 16
03-27-2015, 01:07 AM #1
- Mar 2015
- 7
Vertical line on circular prints with Makerbot 5th gen
Hey all,
I'm finding on anything I print that is more or less circular has a long vertical line the length of the whole print down it.
It appears with makerbot slicing the extruder does a circle then turns around and goes back the other way in the same spot causing this vertical line.
If I use simplify3d slicing this doesn't happen. I would continue using s3d but im having issues with the rafts bubbling and bonding to the print.
If anyone can advise how to fix the vertical line issues I would happy to stick with the makerbot software. Not sure what can be changed in custom profiles to fix this?
Many thanks
Brett
03-27-2015, 01:11 AM #2
- Mar 2015
- 7
Thought this picture might help explain it
03-27-2015, 03:38 AM #3
- Mar 2015
- Slovenia, Europe
- 76
Hi there
If this is 5th gen Desktop then I would suggest to upgrade it to latest Destkop (3.6) and latest Firmware (1.6)
Try again and let me know if it helps.
03-27-2015, 03:56 AM #4
- Mar 2015
- 7
03-27-2015, 08:02 AM #5
- Mar 2015
- Slovenia, Europe
- 76
Maybe you are using old print file, made from some of previous verisons? If so, reslice it.
What is left is Custom profile.
I don't know how familiar you are with it, but generaliy you have to increase distance between start and stop point of extrusion (during those circles).
To do so, is easy: just increase the value of "ozze" distance from 0.1 (factory) to 0.2
Make sure to do so at 2 placese of occurance of this parameter.
You will be able to notice difference even in Print Preview.
If still not good enought then maybe 0.3 .... etc.
I hope this will do
03-27-2015, 05:41 PM #6
- Mar 2015
- 7
03-28-2015, 12:34 AM #7
- Aug 2014
- Montreal, Quebec
- 576
The slicer just had failed on your cylinder.
This happens often with thin wall extrusion, fast print and on top of that if you ever print with high Z layer .
One solution to check, print one, but slowly with .1 or .2mm height AND try to increase thickness of the object itself.
03-28-2015, 04:15 AM #8
- Mar 2015
- 7
03-28-2015, 05:13 AM #9
- Mar 2015
- 7
03-28-2015, 08:24 AM #10
- Mar 2015
- Slovenia, Europe
- 76
Hi
Try out like this:
"preOozeFeedstockDistance": 1.1, (this is in 2 places of profile, change both to same value)
"infill": {
"feedrate": 90,
"temperature_disabled": 230.0
"insets": {
"feedrate": 45,
"outlines": {
"feedrate": 25,
this kind of change should bring you to different results.
