Results 1 to 10 of 11
03-22-2015, 10:23 PM #3
I will update the software this week so that I can combine standard printing with continues. When a big flat surface is printed it will use the normal dipping method and when it prints thin walls it will go over to continues. For now the user will need to set what should happen. If the user sets the dip depth to 0 it will activate continues or maybe I will just add that as an override in my override manager to enable continues and then the user can select which layer to disable continues again. This will be great when printing a box. The front can be printed using dipping and then the walls using continues
New member with print issue
