Results 621 to 630 of 757
03-21-2015, 05:40 AM #621
Hi, I have not read all of this thread. So you might already know this.
I just want to tell you that the Bed Leveling in Marlin does not compensate bumps etc as in its calculation only tilt a flat plane no matter how many points you measure. You can see this in planner.cpp in the function plan_buffer_line() which calls apply_rotation_xyz() for the compensation.
I discovered this the hard way and I have now written a mesh based leveling feature.
You can read about it here https://github.com/MarlinFirmware/Marlin/pull/1619
I don't have the setup to do auto measuring so I use the display and the encoder to measure and step through the points.Last edited by epatel; 03-21-2015 at 05:49 AM.
03-21-2015, 09:29 AM #622
Just updated the code so one can use a G29 command to run the leveling sequence without a display.
03-28-2015, 10:06 AM #623
- Dec 2014
- Canada
- 498
where can we get the version of Marlin with the Mesh leveling feature?
03-28-2015, 10:12 AM #624
- Dec 2014
- Canada
- 498
I see some mesh levelling code in marlin.
its labeled under manual bed levelling
Can you advise how to enable Mesh Auto bed levelling
03-28-2015, 10:48 AM #625
03-28-2015, 11:49 AM #626
It has been merged and is now part of the Development branch. I have also added this short description https://github.com/MarlinFirmware/Ma...BedLeveling.md
03-28-2015, 11:51 AM #627
I don't have any servo etc mounted on my machines so hard for me to add. But another developer is looking at making it fully automatic
03-28-2015, 12:42 PM #628
- Dec 2014
- Canada
- 498
Great, I really hope this helps making ABL more reliable
thank you for your contribution to marlin
03-29-2015, 06:11 PM #629
Certainly no disrespect was intended by saying 'not automatic is a negative' ! It takes time and many steps to get good software! It would be nice if we could have 20 or 30 areas defined on the bed. But to probe that much is not going to be pleasant so that would have to be something saved in the EEPROM. And then my other hope is I get full control over how many layers before the mesh firmware backs off and is out of the picture.
04-11-2015, 08:23 PM #630
- Jan 2015
- 32
I own a TAZ 4 and the X-axis dips at least 0.15mm in the center of the bed due to the weight of the dual extruder.
Can I use the mesh mapping version of the bed leveling code that you created to account for this 0.15mm dip?
I don't have a bed leveling probe, but I would like to manually enter height values for the 4 corners of the bed plus three points along the X-axis (two opposing edges + the center of the bed). Is this possible with your upgrade? Will your upgrade create a concave up map of my TAZ 4 bed?Last edited by inventabuild; 04-11-2015 at 08:59 PM.
New member with print issue
