Results 1 to 10 of 11
Thread: Glue for PLA
03-20-2015, 11:12 AM #1
- Jan 2015
- 306
Glue for PLA
Hey, I am using Cyanoacrylate to bond PLA together. It causes the plastic to discolor and turn white, is there a strong glue that will not do this to PLA?
Thanks
03-20-2015, 11:18 AM #2
Might try some Epoxy 330. No fumes. Bonds very well.
03-20-2015, 11:46 AM #3
- 41
Epoxy works well for me as well
03-20-2015, 12:17 PM #4
- Jan 2015
- 306
How long does it take to set?
03-20-2015, 12:33 PM #5
It takes about 15 minutes to thicken, and a couple hours to fully harden. It will harden in 10 minutes under a heat lamp but that may deform your PLA.
03-20-2015, 01:15 PM #6
- Jan 2015
- 306
Once both tubes are opened, will they dry out and crack or do they stay usable again? I hate opening glue tubes and then coming back in 2 months to a hardened rock of glue.
03-20-2015, 01:25 PM #7
They remain usable. Don't know what the shelf-life is. I've used some that was several years old and it held just fine.
03-20-2015, 02:34 PM #8
I use #4 SciGrip. It is a knock off of #4 Weld-On. It dissolves and melts the PLA plastic together. It forms a very strong bond. There is no discoloration and nothing in the joint but PLA plastic.
http://www.ebay.com/itm/IPS-Weld-on-...item2ebe7161d6
03-21-2015, 01:36 AM #9
- Jan 2015
- 306
Thanks guys
03-21-2015, 07:26 AM #10
I use this stuff: http://www.amazon.com/Glue-Sticks-UH...hu+all+purpose
But it's way way cheaper in the uk. I get 60ml tubes from the pound shop :-)
Sticks anything, particularly good with pla to pla or indeed pla to anything else. Sets almost as quick as super glue and you only use a very thin smear.
Also sticks abs.
