Results 1 to 10 of 20
Thread: Print Speeds
03-05-2015, 05:45 PM #1
- 41
Print Speeds
Just playing with my print settings, including speed as my printer extruder keeps jamming 3\4 way through each print.
Does anyone have any recommendations for speed vs resolution - I'm currently printing at 0.1mm at 1800mm per minute and wondered how that compared to others
Cheers Graham
03-06-2015, 07:47 AM #2
That will probably depend on the type of printer and print head you are using.
I print .1mm at 1800mm/min regularly.
I don't go faster than that, because we move a lot of mass around in the X and Y.
03-06-2015, 09:56 AM #3
- Jan 2015
- Antwerp - Belgium
- 13
Speed isn't everything. I noticed that when I put acceleration and jerk higher, I get shorter printing times, with the same speed-settings !
Instead of lowering your print speed, I would start with lowering these 2 settings.
03-06-2015, 09:49 PM #4
- Sep 2014
- 26
I agree, I'd have to be careful with the speed settings. My 3d printer isn't the best though so this is why I hesitate on experimenting with it. I only use what's the recommended settings.
03-07-2015, 03:24 PM #5
- Aug 2014
- Montreal, Quebec
- 576
What is your nozzle size and does your hotend have some cooler to evacuate the heat that goes upward?
03-07-2015, 03:34 PM #6
- 41
03-07-2015, 03:54 PM #7
- Aug 2014
- Montreal, Quebec
- 576
Are you using some cheap chinese brand filament by any chance?
Because your current hardware and software settings should handle it fine. I have the same set up and able to run it faster (Ultimaker 1 modded)
03-07-2015, 04:42 PM #8
- 41
I'm using the following :
http://www.ebay.co.uk/itm/2313403873...%3AMEBIDX%3AIT
Perhaps I need to spend a bit more ?
03-07-2015, 05:30 PM #9
- Aug 2014
- Montreal, Quebec
- 576
Oh god....
Yes, you may need to spend more on the filament. Also, I am curious about that 99.9% positive feedback, is it the review of the seller or actually the filament. I never deal with ebay or online stuff which is why I ask.
That being said, yes, spent more on reliable filament and colour can change dramatically the print. I tried the following filaments from Affinia, ColorFabb and Reprapper, they all work fine. I do have trouble printing clear ABS from 3dSupply world (cheap material) and it was quite a pain to print.
03-08-2015, 03:13 AM #10
- 41
