Thread: Auto-Level Z delta?
03-04-2015, 04:35 PM #1
- Dec 2014
- 61
Auto-Level Z delta?
I just got a new printer with updated firmware. It has a function "auto-level Z delta"in which you set "max. height change between probe points. " default is 0.50mm. Any ideas what its for?
03-05-2015, 12:54 AM #2
- Burnley, UK
- 1,662
auto-level Z delta << data for auto level Z
max. height change between probe points. << permitted maximum height difference between those points
I think maybe you need to rethink your question or perhaps it is April 1st.
03-05-2015, 10:38 AM #3
it's for autolevelling on a delta printer, at a guess. You're either in the wrong section of the forum or the wrong forum :-)
what printer do you have ?
06-22-2015, 09:55 PM #4
- May 2014
- 35
This Auto-Level Z Delta is in Utilities, on a FlashForge Creator Pro. Which is peculiar, because the instructions say you have to level the bed manually. I'm having Z issues and bed leveling issues and bumped into this in the menu also.
