Results 161 to 170 of 232
03-04-2015, 08:46 PM #161
- Nov 2014
- Brevard, NC
- 182
I was not able to get th octopi.local to work for me either, but used the ip address in the address to access it. http://xxx.xxx.xxx.xxx substitute the xxx's with your id address. I did read on this http://octoprint.org/download/ site that for windows you need to install "Bonjour for Windows" from apples site to be able to use octopi.local address.
03-04-2015, 09:12 PM #162
- Feb 2015
- 371
On a mac. How do I find the IP address of the PI?
Hopefully the web cam and iPad features will be easier to hook up once I get it connected.
03-04-2015, 09:18 PM #163
- Nov 2014
- 522
03-04-2015, 09:32 PM #164
- Nov 2014
- Brevard, NC
- 182
I do not know much about Macs. Someone that know Macs on here might be able to give a better answer, but this page references a way to find that ip address on a Mac by installing nmap & using that to find the ip address, http://www.raspberrypi.org/documenta.../ip-address.md I used a google search for "how to find the ip address of a raspberry pi on a mac" to find this page.
03-04-2015, 09:35 PM #165
- Feb 2015
- 371
Okay, I am now looking at my printer in Octoprint! However, i cannot print anything. I can move the printer around an everything but when I hit print, nothing happens. Can seem to figure out how to get things on the raspberry card and printing. Got some reading to do!
03-04-2015, 10:07 PM #166
- Nov 2014
- Brevard, NC
- 182
I had the best luck using Firefox & dragging & dropping the .gcode instead of using the upload button. I have not tried safari browser with it. Which browser are you using? I manually set the temperatures before starting my print, then under the Action column I click the load button which looks like a open folder icon. Then I hit the print button above the file names & it starts printing.
03-04-2015, 11:27 PM #167
- Feb 2015
- 371
Mine says sd card not initialized.
03-04-2015, 11:53 PM #168
- Nov 2014
- 522
03-05-2015, 10:52 AM #169
- Feb 2015
- 371
Realized that late last night. Still can't print. When I select a file from the file picker the progress bar goes up and then down. If I click print, nothing happens.
I also had an error show up the ONE time I was able to print something. I had a thermal runaway error and the printer shut off.
03-05-2015, 11:08 AM #170
Completely new to 3d printing and...
06-13-2025, 01:52 PM in General 3D Printing Discussion
