Results 1 to 10 of 17
02-26-2015, 09:54 PM #1
- Feb 2015
- 10
Cura settings for PowerSpec 3dPro
Hello
Still new to all this.
I would like to try Cura does anyone know what is the best machine type to choose for my printer?
Would I use a makerbot or custom?
Will work with dual extruder?
Thank you
Brian
02-28-2015, 09:23 AM #2
- Jul 2014
- 83
I would be interested in this topic as well.
I downloaded Cura, and started to look at it, but have had other priorities lately. I think I'll tinker with it more over the next few days, to see what it can do.
I've been working to fix raft generation in replicatorg, and have made some significant progress there.
Cheers,
John
03-01-2015, 05:12 PM #3
- Feb 2015
- 10
I like the idea of the brim instead of the raft
03-01-2015, 08:14 PM #4
- Jul 2014
- 83
I did tinker with Cura, and with Slic3r, yesterday. No joy in getting anything that will print on a FF Pro, though. I know there's a gcode converter to generate an x3g file, but I run Linux, and that tool is windows/mac only. I think i'll keep looking at it though.
Cheers,
John
03-03-2015, 09:03 PM #5
- Feb 2015
- 10
What is the best tool to convert to x3g?
Thanks
Brian
03-04-2015, 12:21 PM #6
- Nov 2014
- 13
This works ok for me -- http://www.thingiverse.com/thing:81425
03-05-2015, 10:39 AM #7
cura should have an x3g plugin - I've never found it. So basically cura won't work.
You're petty much stuck with makerware and simplyfi3d - which you pay for. But think long term and it's worth it.
03-05-2015, 04:56 PM #8
- Jul 2014
- 83
I tried to export the gcode that cura puts out and open it in replicatorg. It didn't work very well...
It appears that the start/end code is presented as text in the profile for the current project. I was thinking of building a profile with replicatorg/flashforge gcode in place of the cura stock code, to see if that would work.
I usually print over the usb port, so not having .x3g files wouldn't bother me, if cura could output a gcode file that would print on the ff pro...
Cheers,
John
03-06-2015, 12:30 AM #9
- Mar 2015
- California
- 28
Simplify3D, while not free is an awesome tool. So much better than the others I've tried. Slices so fast you'll think it isn't working at first. Lol. At least I did!
03-06-2015, 05:47 AM #10
You're missing the point - even the makerware software converts to .x3g files before printing. Over usb or from the sd card.
You can't use standard gcode unless you change the motherboard. It's opensource but done in a very odd way :-)
Yes you have to change the start and end gcode - but you also then need to convert to x3g before you can print.
