Results 1 to 10 of 10
Thread: Resin dye
01-16-2014, 09:49 AM #1
- 219
Resin dye
presumably you could buy the natural resin and add your own pigments or dyes to color it ? As long as the dye doesn't affect the curing properties.
01-16-2014, 03:35 PM #2
01-16-2014, 04:10 PM #3
- 219
It occurs to me that unless you want to color a large amount of resin, various size buoyancy rings which float on and a few millimeters into the surface of the resin, would be useful. This would allow you to select a ring only slightly larger than maximum x,y for the object to be printed. The ring may need to be loosely tethered by 3 cords at 120 degrees to prevent drift. This idea could drastically reduce the volume of resin required. Could that work?????
01-16-2014, 04:34 PM #4
- 219
01-16-2014, 08:11 PM #5
- Sep 2013
- San Diego
- 210
Absolutely. However, with the peachy printer, you can just change the reservoirs, and therefore negate the need for a floating ring. Want smaller prints? Use a smaller reservoir.
Maybe have three sets of reservoirs would help? A small, medium, and large could solve the problem, and be of minimal annoyance.
01-17-2014, 02:59 AM #6
- 219
01-17-2014, 03:34 AM #7
- 219
01-18-2014, 04:24 PM #8
- Sep 2013
- San Diego
- 210
01-18-2014, 05:37 PM #9
- 219
02-04-2014, 09:31 AM #10
- Feb 2014
