Results 21 to 22 of 22
03-02-2015, 01:15 PM #21
Actually that's a stock photo I grabbed from Google but that really is how they look after removing the support material. I use Rhino for 3D modeling. We cast it the same way you would cast wax (lost wax casting). With a slightly runny mix of investment, you can get some better detail in the casting. However, the difficult part is not polishing away all of your detail later.
03-02-2015, 02:53 PM #22
- Oakland, CA
- 935
There are machines that can do that, or come pretty close to it. EOS of Germany makes a micro-laser sintering machine that prints directly in metals. Here's some information about their process: http://www.eos.info/eos_pressemitteilung_3dmicorprint Of course, these machines aren't exactly cheap - last time I heard, they were about 1 million USD each. But you might be able to find a service bureau that has one and can make these parts for you.
If you want ceramic parts instead of metal ones, there's an Austrian company, Lithoz, that uses a process called lithography-based ceramic manufacturing to make small highly-detailed objects. I'm not sure they can hold the tolerances you need, but you could ask them about it: http://www.lithoz.com/en/products/cerafab-7500/
Andrew Werby
www.computersculpture.com
