Thread: Problem with STL file
02-25-2015, 10:30 AM #1
- Feb 2015
- 11
Hello,
I have an STL file that converts and prints fine on a CUBIFY 3D printer. But when I import the same STL file into flashforge G software and generate G code then print on flashforge PRO it hardly lays down any plastic at all. The object is a honeycomb like web a little over 1mm thick. I have disabled the raft feature. And really I have to just scrape the little bit of plastic it lays down off the bed. The shape looks correct though.
Any thoughts?
02-25-2015, 02:14 PM #2
- Sep 2014
- 54
Doesn't slice properly for me in Simplify3d either, though the model shows up, when you prepare to print (slice it) it shows nothing at all and 0 build time. The resulting Gcode file is empty bar settings too.
Oddly though the model passes all checks for manifold etc.
02-26-2015, 08:04 AM #3
- Feb 2015
- 11
Bobbler,
This file actually prints some material and in the proper shape, it is just so little material I have to scrape it off. Was this your experience? On the Qube it prints out a little over 1mm thick.
Thanks
02-26-2015, 08:34 AM #4
- Sep 2014
- 54
Hi fotomatcion - no I didn't try to print it as it shows nothing for me in the preview window after slicing it and contains nothing in the resulting output Gcode - it wouldn't even print in that case.
02-26-2015, 12:04 PM #5
in Netfabb & KISSlicer it shows a height of 0.3mm
