Results 151 to 160 of 321
Thread: Flashforge 3D Creator forum.
01-23-2015, 01:07 PM #151
- Jan 2015
I'm at my wits' end. I keep running into problems with the corners curling on my prints.
I'm running a FlashForge Creator dual extruder (wooden frame). I'm printing in ABS with kapton tape and a ton of Aquanet.
I've tried the following things already:
Levelled the bed
replaced the kapton tape
tested at speed settings (40/70, 65/90)
tested with various heatbed temperatures
75C -> pretty bad lift
80C -> slightly less lift
85C -> about the same as 80C
90C -> only right side lifts
95C -> slightly worse than 90C, left and right side lifts
100C -> left and right sides lift
110C -> Good way to make a bowl
I've played around with the extruder temps as well. At 230C, the raft is pretty much fused to the bottom of the print, and there are some melty bumpy textured portions of the print. At 220C, the raft releases fairly cleanly with a little work and decent layer adhesion. At 210C I see a lot more lift from the print bed and get the occasional poor layer adhesion. In all cases it starts out looking great, but at some point between 11% and 26% complete, the corners lift and curl upwards.
I've tried using MakerWare and ReplicatorG with similar results, although MakerWare's rafts seem better and the slicer is MUCH faster for my model.
I'm trying to print a quadcopter arm. It is basically two boxes 1.5" wide by 1.5" high by 0.25" deep that are connected by a solid 5.5" cruciform span (a 5.5" X sandwiched between two plates). I've tried two different spools (both black) of ABS from two different vendors with similar results. I've tried insulating the printer (aluminum foil wrapped around cardboard and taped over the open sides, covered whole unit with blanket), and the results are similar.
Anyone have any suggestions for what to try next?
edit: Added 1" square "mouse ears" to the corners. Helped hold down one side. Added bigger ears to the other side, trying again. Will update with a status.
edit 2: tested twice with large "mouse ears". Still failed. Going to run one of the test prints that came with the printer to see if that is having problems too.Last edited by caseless; 01-23-2015 at 05:42 PM.
01-24-2015, 02:20 PM #152
Is the printer fully enclosed? If not try that.
01-25-2015, 09:01 PM #153
- 349
Or try PET which does not curl.
01-26-2015, 06:37 AM #154
- Jan 2015
02-15-2015, 02:18 AM #155
- Jan 2015
As you can see, my ends are pulling up. The raft sticks fine. ABS. Leveled right before printing. Print bed is at 110 deg, using Kapton only. Any ideas?
02-15-2015, 02:24 AM #156
- Jan 2015
In addition, I would have liked to have printed this in the other direction, but I have problems manipulating the drawing in Replicator. It's just all over the place using the mouse. Most of my larger builds pull up like this.
02-15-2015, 02:26 AM #157
- Jan 2015
This parts box pulled uo as well.
02-19-2015, 10:31 AM #158
Hi. I have a small problem. Just bought a Flashforge Creator Pro and I didn't open it well and it's gone crazy. )
I am trying to calibrate it, but when I run the software from the SD card, the nozzles move to the back, into the corner and start to bump into that corner repeatedly and make a horrible noise.
Any ideas how to fix this?Printare 3D Bucuresti
Any sufficiently advanced technology is indistinguishable from magic. Arthur C. Clarke
02-19-2015, 11:26 AM #159
sounds like a broken or loose wire on the limit switch back there...
02-19-2015, 11:29 AM #160
but when the switch is activated a green button lights up...
