Results 1 to 9 of 9
Thread: My first 3D-printed model
02-10-2015, 04:22 AM #1
- Jan 2015
- 62
I got a Geeetech 3d-printer, and printed my first object. Here is how it’s made from ABS filament, and a lot of details about the model.
Start
Create 3D objects in reality, sounds difficult and magical. In the past, only factories can do it. But now it’s simple and the method is easy to understand.
A 3D model is cut into pieces or layers in computer, each layer is thinner than 1mm. Printing a layer is easy, just like painting with melting plastic, and then other layers upon it. It gets thicker and thicker and becomes the model you want.
Grids
In fact, the model is not totally solid. As you can see grids in the model, especially in the middle(the edge is solid). I think the grid structure can save material, it’s lighter but also has required strength--solid doesn’t means strong all the time.
Notes
Neighbor layers should be adhere to each other, however sometimes they are separated, because of unsuitable temperature or layer number. Changing conditions of printing can get different effects. And the bottom layer can not be easilypaste on the glass board below it, so glue is needed, don’t forget clear it after print.
Views
Different views of the 3D model, it’s only 5cm tall but consist of more than 100 layers and spent more than 4 hours. Not so fast but i think it’s cheaper and more convenient, than any other ways to get this 3D model. By the way, I purchased the 3D-printer from Geeetech: http://www.geeetech.com/acrylic-geee...it-p-884.html, it’s suitable for beginners like me.
02-10-2015, 05:15 AM #2
An interesting choice for a first model?
02-11-2015, 04:06 AM #3
- Jan 2015
- 62
02-13-2015, 03:48 AM #4
- Feb 2015
you have printed so many objects now? i am still assembling it, but i have a problem in wiring of the ramps 1.4, can you help me? if you can give me some pictures, that would be much better, thanks in advance.
02-13-2015, 03:57 AM #5
- Jan 2015
- 62
I am still looking for something amazing to print. I printed my first model casually, you know , selecting an STL file randomly, because I just wanted to see how well can it print.Actually, I alse spent a lot of time assembling the printer. You can visit their wikipage: http://www.geeetech.com/wiki/index.p...side_panelHope it will help you successfully assemble your printer. Good luck!
02-13-2015, 04:27 AM #6
- Feb 2015
- 9
It looks like part of sth, maybe a castle
So do you know where to get sth interesting that can be print? THX
02-13-2015, 05:31 AM #7
Why not print the wrench that NASA got printed on the International Space station? Here is the link to the .STL files for the NASA Wrench.
02-13-2015, 09:38 PM #8
- Jan 2015
- 62
Actually, I don't know what I printed is either. I download the file without watching its instruction.
You can find many model files at : http://thingiverse.tumblr.com/
02-13-2015, 09:47 PM #9
- Jan 2015
- 62
Please help dial in my printer
Today, 11:02 AM in Tips, Tricks and Tech Help
