Results 131 to 140 of 232
02-11-2015, 08:51 AM #131
- Feb 2015
- 70
Just to add a clarifying statement: The Pi-1 and Pi2 have different cpus, meaning images pre-compiled for the pi-1 will not work directly on the pi-2.
http://thepihut.com/blogs/raspberry-...raspberry-pi-2
So you cannot simply grab an OctoPi image and install it on a Pi-2. The above link does give instructions for converting an image to run on the pi. I would expect, from my experiences as a software developer, that it probably will not be as simple as they make it seem. A quick Google search turned up no evidence that anyone is working on porting, although someone must be somewhere.
With all that said, OctoPrint will very likely run without issues on the Pi-2. After all, it is just a piece of software, and the hardware environment is essentially "the same". But if you were hoping for the convenience of OctoPi, it looks like it will take a little more work.
02-11-2015, 11:00 AM #132
- Nov 2014
- 522
02-11-2015, 01:57 PM #133
- Feb 2015
- Flagstaff, AZ
- 73
02-11-2015, 11:44 PM #134
- 74
02-12-2015, 08:52 AM #135
- 134
From the developer of OctoPrint:
Gina Häußge originally shared:
So I finally came around to flashing my current custom development version of OctoPi (incl. slicing via Cura and netconnectd) on a MicroSD and test it in the RPi2. I also flashed the exact same image on an equal card (both 8GB MicroSD, Transcend, class 10) and put that in an RPi B.
First of all: the first boot (where it needs to generate the SSL key and all that) is definitely faster. I didn't measure the time, but where it goes something like "wait for it wait for it waiiiiiiit for it" on the old one, it's more like "3, 2, 1, lift-off" on the new one.
Secondly: Slicing. I uploaded and sliced three STLs on both Pis, with results that made me giggle with joy:
STL1: RPi1 => 36.87s, RPi2 => 14.71s, Factor => 2.50
STL2: RPi1 => 173.85s, RPi2 => 69.55s, Factor => 2.49
STL3: RPi1 => 16.23s, RPi2 => 5.94s, Factor => 2.73
So slicing on the RPi2 with CuraEngine is about 2.5 times faster on that limited set of tested models.
Third, loading: An uncached reload of the main page (so without the new server side cache I added recently) until after the full handshake with the server through the websocket takes around 16s on the RPi1 and around 8s on the RPi2 - this IS noticable.
02-12-2015, 09:14 AM #136
The 12V rail needs enough current to drive the printer. I don't know what the requirements are for the 12" bed, but I'm sure it's in Colin's docs.
If you're running the electronics off the 5v line, any ATX power supply will have enough. But if you're running off the 5VSB, I would think you would want at least 2A. 3A would give you some margin for the servo.
I'm running HP server supplies that deliver 7.5A on the 5VSB bus and I recommend that route. They're all over eBay.
02-14-2015, 04:07 PM #137
- Nov 2014
- Brevard, NC
- 182
I am probably a glutton for punishment, but I ordered the Raspberry Pi model 2 B since MCM electronics had it for $35 & it does seem to run the octoprint. I also ordered the
5MP Raspberry Pi Camera Board
Wi-Pi Raspberry Pi 802.11n Wireless Adapter
5V 2.2A Micro USB Switch Mode Power Adapter
16Gb Sandisk Ultra MicroSDHC Class 10 Card
My router is within a couple of feet of the printer, so I did not really need the wireless usb unless I decide to move the printer to another spot in the house. I also ordered a 24" flex cable for the camera from amazon that someone else mentioned. I will see how this goes when the shipment arrives.
02-22-2015, 12:19 AM #138
- Feb 2015
- Flagstaff, AZ
- 73
So I have a Pi B, and need to get a camera, if I buy the raspberry pi cam it won't tie up a sub port, if I go that route and use the two USB ports for the printer and wifi can I run without a powered usb hub?
also used book store has PS3 cams used for $15 but that would require the hub, is that printer just as good as the pi cam?
thanks
02-22-2015, 01:05 PM #139
- Nov 2014
- Brevard, NC
- 182
I am not sure what your comment "is that printer just as good as the pi cam?" means. I have only hooked this pi to my TV so far & do not have it configured correctly yet. It is nice to have the 4 usb ports. I am using 3 of them with the mouse, keyboard & wireless adapter. One way you could also save a USB plug would be to get a Network extender like the Netgear WiFi Range Extender WN2000RPT. That way you could plug a network cable between the Raspberry Pi & the Range Extender & free up the usb port you are using for the wireless adapter. I am not sure that would be less cost than getting a Raspberry Pi B+ or model 2 though.
02-22-2015, 01:56 PM #140
- Nov 2014
- 522
now that i have octoprint setup, i use 2 usb ports... 1 for the camera and 1 for the printer everything else is done over the network. i were to resetup my wifi I would be using 3. there isn't necessarily a need to worry about usb port usage. the only real need for a usb hub is if you are using a camera that draws a lot of power. i use a single cell phone usb power adapter with a 1.5 amp raiting, I run the raspberry pi that has the ethernet port the printer and the Logitech C310 webcam all hooked into it with no issues at all.
I don't know what else you might plug into it really. at one point i also had the suggested wifi adapter in use instead of the ethernet port and also had no issues.
