Thread: ZPrinter 450 Delicate Structures
02-11-2015, 04:04 PM #1
- Feb 2015
Hi there,
I am trying to print 3D structures on the ZPrinter 450 but I am not able to print anything that won't break apart.
Do you guys have any tips on settings for printing things that are more delicate?
I tried to print this -> http://www.thingiverse.com/thing:184694
And it didn't hold together at all. I am trying to print things that have thing parts like the model above.
Thanks!~
02-11-2015, 04:12 PM #2
How long are you leaving the build in the machine after it finished? It needs at least an hour (and 24 hours is better)
When you do remove the model, be as careful as you brushing/blowing the excess plaster off and then there's a selection of coatings which you can use (z-bond/colour-bond etc.) these will infiltrateeeee the model and make it much stiffer.
You can also put it in an oven to dry it.
02-11-2015, 04:15 PM #3
- Feb 2015
02-11-2015, 04:37 PM #4
I use a silicone pastry brush on our z-corp machines. Works much better than normal paint brushes.
When you blow the excess powder off be sure that the compressor is turned right down.
You may want to look at the age of your build materials and could also try increasing (you can't do it by too much) the amount of binder it jets out.
