Results 51 to 54 of 54
Thread: simplify3d
02-09-2015, 10:42 PM #51
- Nov 2014
- 58
yes is was changing it on S3d trying to see if it make a difference with some Gaps/Layer Shift between layers im getting . but i didn't know the fact that the firmwares limit the movement....
also i was wondering what average speed works for you . i have found that the default setting are Extremely Fast compromising the print quality . i tamed down to this and still found to be fast for prints like this one i just did .
ABS 0.3mm 230C 15% infill
02-09-2015, 11:28 PM #52
- new jersey
- 752
printbus, what pichuete is showing in his pic for the wipe is what i normally see. its just the way it is. the nozzle drags on each layer in that spot changing the look of it. on mine there is nothing actually on the surface that you can feel. it just seems to make the plastic look different.
11-05-2015, 09:13 AM #53
- Nov 2015
hi . the link does not go !! can you send me your prusai i3 profiles what you have make ! THX
11-05-2015, 09:15 AM #54
- Nov 2015
