Thread: Simplify3d Starting Gcode
02-07-2015, 12:04 PM #1
All,
I need some help with starting gcode for Simplify3D, can you share what you use please?
02-07-2015, 12:28 PM #2
There's also help with end g-code in http://3dprintboard.com/showthread.p...7-Ending-Gcode
Here is the starting gcode script I use with S3D. Note that I don't have ABL, and my home is at the front-left corner of the printer. I split up the homing process to first move the nozzle to the front left, then I prime the extruder so I can wipe it manually, and then I home Z.
Code:; Simplify3D will already have printer at temperature by this point M107 ; start with print cooling fan off G91 ; relative positioning G1 Z10 F120 ; raise up before homing to clear clips and prepare for wiping away priming G28 X0 Y0 ; home X and Y G1 E8 F180 ; extrude 8mm at 3mm/sec to prime G1 E-2.5 F900 ;retract 2.5mm at 15mm/sec G92 E0 ; reset extruded length G28 Z0 ; home Z G90 ; absolute positioning M82 ; extruder to absolute mode M117 Printing...
02-07-2015, 01:14 PM #3
