Results 141 to 150 of 189
Thread: Show your MODS
02-04-2015, 03:50 PM #141
I didn't try without the adhesive. In the forum several people did, and tried many other products to get it to stay down. I think in the end it worked to not use adhesive, but the PEI can flex and bow and so even with clips didn't always stay on the bed firmly. Now one thing to consider, those folks have a round bed. I am not sure if it would make a lot of difference with our square beds, but you could always try it first before using the adhesive. I read through like 600 posts, and decided to just not mess around and just mount it. It isn't a permanent fix, as you can remove it and clean the glass and try again, or whatever.
02-04-2015, 03:52 PM #142
- Dec 2014
- Canada
- 498
I typically print onto 6mm Borsilicate glass. but i also have a pieces of 3mm glass that I can use to support under teh PEI
hold it down with Binder Clips.
02-04-2015, 03:53 PM #143
robh2, yes I used the adhesive to hold the PEI to the glass and clip the whole thing down. to the heat bed. The main guy on that thread even if he wanted to, flip the glass over and print on the glass with the PEI down on the heat bed, for other materials.
02-04-2015, 03:56 PM #144
I got my sheet here.http://www.mcmaster.com/#8685k41/=vrmwjq
Then glued it to a piece of .125" acrlyc with weldwood contact cement.
02-04-2015, 04:06 PM #145
They also have thicker if you dont want to glue/tape it down. http://www.mcmaster.com/#catalog/121/3649/=vrn0h2
02-04-2015, 04:32 PM #146
Good info. I'll try some.
Bambu P1S/AMS
02-09-2015, 11:13 AM #147
- Dec 2014
- 28
I know it isn't exactly a printer mod per se, but Gmay3 suggested I post my Folding Spool here:
http://www.thingiverse.com/thing:671449
It works great for sample/specialty filament coils!
02-21-2015, 06:28 PM #148
- Feb 2015
Spool Holder
I've had my i3v 10" for about 3 months now and have been reading the forums for a while. I finally got around to making and documenting something for my printer! I've used other spool holders that I downloaded but they always broke, so I finally made my own. I think it works works pretty well and looks cool too. I modeled it after the Eiffel Tower..
http://www.youmagine.com/designs/eif...ool-holder-i3v
I'd love to hear your guys opinions!
02-27-2015, 07:35 PM #149
- Nov 2014
- 58
Y Belt Holder
hi guys i willshare my Design for a Y belt holder upgrade that i did. i didnt like the way how the y belt is attached to the bed with zip ties so i decided to make this . i found is a more secure and easy way to align the Y belt .
If anyone is interested . i already upload it to thingiverse
http://www.thingiverse.com/thing:702152
03-12-2015, 06:48 AM #150
- Dec 2014
- 21
Hi all
That is my first post here.
I finished my 12" last week. At the moment I am still adjusting und configuring it.
For my first mod I made a frame for the lcd screen. More look than usefullness.
http://www.thingiverse.com/thing:718725
BR
PGX3S
