Results 11 to 16 of 16
02-02-2015, 03:42 PM #11
- Dec 2014
- 16
Do you happen to have a picture of where you put the shim? I have a 1.75mm and a 3mm that are different sizes and don't have the range on X axis to offset it so I am looking into doing a shim, do you put in between the Double Grove Mount and the XCarriageDoubleShelf on the long side?
02-02-2015, 07:21 PM #12
02-02-2015, 11:33 PM #13
- Dec 2014
- Canada
- 498
I made a tilting plate for the i3v X carriage
printing it now, going to try it out tomororw
I will post pic if it works!
http://www.thingiverse.com/thing:664362/#files
02-03-2015, 06:46 AM #14
- Jul 2014
- Eastern Colorado
- 536
Looks good, Adam. I'm just concerned about the strength of the part in these two places:
Let us know how it turns out.
02-03-2015, 09:58 AM #15
- Dec 2014
- Canada
- 498
Yep I noticed that too, I will revise the design
02-03-2015, 11:04 PM #16
- Dec 2014
- Canada
- 498
I posted new stl, and photos, I have this now installed.. and right now both my hotends appear to be dead level.
I levelled my X carriage to the Y rails.. to remove any compensation i tried earlier
calibration isnt hard., pull the bed all the way forward so the hotends are just touching the back of the bed,
loosen bottom two tilt bolts, lower hotends until they touch bed. slight pressure from lowering will make the hotends automatically tilt
until they are both touching.. you can also wiggle it until it looks level.. double check with gap tool and tighten bolts from behind and underneath and its done.
