Results 561 to 570 of 757
01-27-2015, 12:09 PM #561
- Jan 2015
- 12
Yup, same thing happens to me Tyson, on about 4 out of 10 G29s i send. Totally stumped and cant figure out what its related to or triggered by. Happens like this: it does 8 probes without a hitch, starts doing the last, touches once, goes back up, starts lowering slowly and as soon as probe triggers (or there about) the LCD goes blank, and the whole thing seems to freeze up. Any ideas? Other than that been loving the enhanced ABL and the fact the probe doesnt no longer scrapes the bed on retracts, thanks Roxy!!!!
01-27-2015, 12:40 PM #562
Glad I'm not the only one experiencing this. I'm still trying to figure it out. I have determined that I don't need to do a full power off, power on to fix it, I just need to disconnect from Pronterface and then reconnect and I can do one probe matrix without any problems.
Tyson
01-27-2015, 01:12 PM #563
- Jan 2015
- 12
01-27-2015, 01:26 PM #564
- Aug 2014
- 627
Are you guys using the new maker branch or the original from Roxy?
01-27-2015, 01:31 PM #565
01-27-2015, 02:59 PM #566
- Jan 2015
- 12
Same, followed instructions on page one. I did try the marlin version that incorporates Roxy's code just to see if it would fix the freezing (and SD init fail thing) but it all went terribly wrong n i went back to original marlin with the code from the first page. And when i try to print from SD (i found another work-around for the SD fail issue) i also get the same freezing once in a while, except the LCD starts blinking, probe moves in time with the blinks, if that makes any sense and then the whole thing resets and i have to do the trick to get the SD working all over again, which involves powering off, plugging the usb back in, checking on the LCD that it reads the card, turning the power on and quickly unplugging the usb as sometimes it resets shortly after powering on with the usb plugged in, which in turn resets the SD card, somehow... And i have to repeat the whole ritual. Forgive me if i sound as if like the only thing i haven't tried is giving it a sacrifice to please it, but the coding/programming thing is very new to me and I'm still just getting to know with the printer itself
01-27-2015, 04:03 PM #567
- Aug 2014
- 627
Interesting because I do not print via SD card and I do not get any freezing.
So, it would seem they are interrelated somehow.
01-27-2015, 04:35 PM #568
Sure sounds like the 5V from the MEGA2560 board could be dropping out. Do you have another USB cable/computer to try or a powered USB hub to feed the USB through? Maybe the USB port on the computer you're using can't handle the additional load of the servo running; if it drops out the 5V regulator on the MEGA2560 board certainly can't handle the added servo load for long.
01-27-2015, 04:46 PM #569
- Jan 2015
- 12
Ive just started a print but i can try to disconnect the LCD with the card reader once its finished and see if it makes a difference, but the freezing happens regardless of where the code is coming from, SD or Pronterface/Repetier... And it is also pretty inconsistent, almost gremlin-like. Seems to happen if, like Tyson said, the printer stays connected to Repetier for too many G29s without disconnecting. But that won't apply to SD, and not sure if Tyson is experiencing the same issue but i still do get the freezing on the 9th probe once in a few prints even though I've got to shut everything down to get the SD to initialise.
01-27-2015, 04:56 PM #570
- Jan 2015
- 12
I do have a 5v USB charger, will give it a shot but not sure how it would work with my SD initialisation ritual as it only seems to work on only one of the 2 usb ports on my laptop. And in general thats the only usb that i can connect to the printer with, which is extra awkward... Thank you both for the suggestions, will give them a go right after i finish printing this duck call
