01-26-2015, 03:46 PM #2
- Jan 2015
- 17
Solved.
My print fan is new for the double extruder build, and is apparently quite effective.
When a small part is printed in the center of the heated bed (which is directly above the thermister) the spot on the bed cools down enough to trigger the shutdown. Ok then!
New member with print issue
