Thread: Fume Extraction
01-25-2015, 01:15 PM #2
- Aug 2014
Fans definitely cause a draft, but as long as you're not blowing air directly at the print (or sucking a huge amount of air directly past the print), you should be ok with just a window fan. I personally use a computer cooling fan mounted on top of my printer and most ABS prints come out ok
