Results 21 to 30 of 109
01-17-2015, 02:04 PM #21
avrdude is the tool used to program the flash memory inside the MEGA2560 processor, so that's where something is going wrong. Have you tried to upload from the Arduino IDE a second time? Have you previously been able to upload OK?
01-17-2015, 02:05 PM #22
- Dec 2014
- Canada
- 498
right now there is a large space between the hotend and the bed, after it completes the ABL
01-17-2015, 02:06 PM #23
- Dec 2014
- Canada
- 498
01-17-2015, 02:13 PM #24
- Nov 2014
- 522
there will be a space between the hot end and the bed if you are running G29 stand alone. Try doing a calibration cube or something small with G29 added to the custom G-code after the G28 and see if it prints properly.
That's odd that your having trouble with it flashing the memory, Just to cover all of your bases be sure to use the short USB cable provided by Colin, because interefence can be had with longer cables, If that doesnt help there is a chance that there could be an issue with the flash. If that's the case contacting Colin for a replacement board will be your only option just test extensively
01-17-2015, 02:21 PM #25
- Dec 2014
- Canada
- 498
i did restart Arduino and it uploaded fine
I do have a long usb cord, but i need it to reach my desktop machine
here is the video
https://www.youtube.com/watch?v=ld9Cl6ysiLA
01-17-2015, 02:27 PM #26
- Dec 2014
- Canada
- 498
so now how to i expand the probing area to cover most of my bed
01-17-2015, 02:31 PM #27
- Nov 2014
- 522
Ok, so when you setup ABL, it doesnt home like it traditionally would when using a regular Z endstop, obviously.
ABL is meant to be used in conjunction with G28, as you have setup.
on slic3r, cura, and kisslicer, sorry no experience with simplify3d, there is an area for custom start and end G-code i would expect simplify3d would as well. You print something quick like a single wall cube, and add G29 just after the G28 in the startup G-code. So that after heating the printer will home then auto level, after auto leveling it should go to the start position drop down to the bed and begin printing. At least that's what mine does.
I wish i was at home to take a video and show you mine as well, but sadly i'm at work...
Oh and i'm a little jealous of your cold end... The color i got was brown...
01-17-2015, 02:33 PM #28
- Nov 2014
- 522
01-17-2015, 02:33 PM #29
- Dec 2014
- Canada
- 498
Video of first test print
https://www.youtube.com/watch?v=BqXocqHU7qY
01-17-2015, 02:34 PM #30
- Nov 2014
- 522
Has anyone thought about setting up a makerfarm chat somewhere like IRC? not that many people would be there all the time or anything... just a thought
