Results 1 to 10 of 28
01-14-2015, 05:17 PM #11
- new jersey
- 752
thats great and all but the vase models you are printing are not going to be prone to warping and are not any kind of warp test at all. almost anyone can print them in abs with their normal setting and come out great looking. its inherent in the design. to really see what you have as far as warping and layer adhesion you need to print the same object to compare results. for this make yourself an 100x50mm box with 2mm walls. print the box 2" high. use the same model over and over with each change then compare results. any way you look at it, you are not going to stop mother nature. abs will warp no matter what you do. why everyone uses abs anymore i have no idea. move on to pet. its 5-10 time as strong as abs, almost the same heat resistance and almost no warp.
