Thread: Cura config
01-11-2015, 03:58 PM #1
- Dec 2014
- Canada
- 498
Cura config
Im trying out Cura for the first time
I think ive got it setup fine
but it sure feels like its printing faster compared to slicer
with same speed settings
01-13-2015, 01:26 PM #2
- Nov 2014
- 34
I have been using Cura also because slic3r often gave me troulbe slicing models that Cura has no issue with. I have also noticed that cura seems to move a lot faster, in fact I often have to significantly slow down the feed rate to get nice prints. Not the biggest deal in the world, I've added it to the list of things to experiment with but I have bigger fish I want to fry for right now.
01-13-2015, 01:37 PM #3
Of course, print speeds and travel speeds are settings in both slicers. Assuming they're set the same, however, part of what both of you are seeing as faster printing is likely the fact that Cura isn't doing near as many non-printing moves. Every one of those extra moves adds time, especially after factoring acceleration and deceleration for them, and retractions for them if they're required.
Take the same model and slice in both. Then use a gcode viewer like http://gcode.ws/ to view each file. Scroll through the print layer by layer. You might be quite surprised at how much more complicated Slic3r makes the route planning.
01-13-2015, 02:08 PM #4
01-13-2015, 02:25 PM #5
01-13-2015, 03:00 PM #6
- Burnley, UK
- 1,662
I found Cura the best out of all the ones I tried but I can't get round the fact that holes are a lot on the small side as is any internal area.
01-13-2015, 03:05 PM #7
