Quote Originally Posted by BLKKROW View Post
Well I have found the two pairs of pins that show resistance, on my new motor. I will pull off my old motor and check that also.
My main question is the wiring. Do the two pairs or A and B have to be wired to a matching A and B from the old motor? Like A to A and B to B or can I swap them around?
If A and B are swapped on one coil then the motor will run the other way round. If they are swapped on both coils it will be OK. If you do not wire correctly and swap a terminal from coils one and two then the motor will not do anything.
