Results 1 to 9 of 9
Thread: Won't stick on right hand side
01-09-2015, 02:24 PM #1
- Jan 2015
- 6
I can't get my prints to stick on the right hand side, iv been trying for weeks, iv calibrated it about a thousand times. And tried temps up and down, but it just won't grip on the right hand side.
It's a duplicator 5s mini
01-09-2015, 05:11 PM #2
01-10-2015, 02:18 AM #3
- Jan 2015
- 6
I'm using the masking tape that came with the printer. But why would it always be the right hand side???
01-10-2015, 04:34 AM #4
Try wiping the surface with alcohol after laying the tape? A vid I saw on youtube suggested not only wiping down where the tape sticks, yet also the tape that has been stuck down.
Another thought is if the tape is getting laid right to left, what are you doing when the tape is stored between prints? It sounds like the outside of the tape roll is getting a contamination (some kind of oil) and when you lay it down that contamination is removed as you get further across the bed.
01-10-2015, 05:31 AM #5
- Jan 2015
- 6
That's some good ideas I will try a few more things later. Interestingly tho it seemed to do the same when I printed straight to bed.
01-10-2015, 09:17 AM #6
01-10-2015, 09:26 AM #7
Also, get a thermometer and check the temps over various locations on your bed, if one side isn't heating up.....
01-10-2015, 10:13 AM #8
01-10-2015, 08:19 PM #9
- 349
Sounds like leveling to me.
