Results 11 to 19 of 19
12-19-2014, 02:49 PM #11
- Nov 2014
- 19
I will try the brim. Though it bends quite a bit so I'll need to use a brim so large I won't be able to print bigger than 8x8cm model on my 18x18cm bed, or less.
12-20-2014, 05:16 PM #12
- Aug 2014
- Montreal, Quebec
- 576
Did the firmware change something to the fan ?
12-23-2014, 02:37 PM #13
- Nov 2014
- 19
Which fan? The extruder only has two fans, one cooling the filament as it goes in the barrel and another one in the back of the extruder cooling the extruder motor. Both are always on.
12-24-2014, 12:16 AM #14
- Aug 2014
- Montreal, Quebec
- 576
Ah, I thought you had a fan pointing at the nozzle that cools the printing, that could be a problem if it is on too early.
12-24-2014, 12:21 AM #15
- Nov 2014
- 19
what result does that fan serve?
12-25-2014, 01:22 PM #16
- Aug 2014
- Montreal, Quebec
- 576
To actually cool as soon as possible and to prevent warping in the printing layer. It is an example where you can have PLA warping stupidly just as much as ABS. The time spend on the print layer is too short, that layer is just still too hot and does funny thing.
I feel this fan is much more situational though, it does more harm than good. If you want to print like small objects with thin wall, that fan will be use frequently. But that being said, if that fan is on without having a brim, it's pretty much guarenteed to have bottom warping.
12-25-2014, 01:52 PM #17
- Dec 2014
- 18
Try moving the machine. There is a possibility of a draft.
01-10-2015, 10:13 PM #18
- 349
Or maybe the flashing reset the bed temp.
01-11-2015, 09:19 AM #19
If it is a fan issue. Change the setting from turning on immediately to turn on after 5 layers and see if that helps. I have seen this setting in both Cura and Repetier-Host
