Results 11 to 17 of 17
12-16-2014, 09:52 AM #11
- Another method of optimization is adjusting the model's facet resolution. It affects both the print duration and the print's overall quality. I do a short article HERE describing the Pros & Cons between high/low resolutions.
12-24-2014, 10:37 PM #12
- 349
Why does auto-cooling slow it down?
12-26-2014, 06:31 PM #13
- Dec 2014
- Portland OR
- 43
Print time is only really accelerated on tall (Z) prints.
I believe this issue stems from the difference of using PLA or ABS. (Slic3r mentions how constant cooling is harmful for ABS)
12-27-2014, 02:53 PM #14
- 462
12-27-2014, 03:02 PM #15
- 462
You might not be able to use this (I don't know what printer you have, but I assume it's a Makerbot), but I just got E3D's new volcano hot end running with a 1.2mm nozzle and reduced print time for the 20mm calibration cube down from 7 minutes to 2 and a half. Layer height 0.56mm and extrusion width about 1.4. Using 3mm filament keeps the extruder from working too hard.
12-28-2014, 12:45 AM #16
- 3D Printer Tellus
- 83
Use Cura Enginee, it slice faster than SLIC3R, then level up to 0.3 mm layer high, speed hmm , test with 90 mm/s. If no support is needed unblock the support.
12-29-2014, 07:42 PM #17
- Dec 2014
- Portland OR
- 43
While Cura promised a 99 minute print time, the reality was far from that, and I canceled it a quarter way through anyway as it had failed.
