12-20-2014, 12:45 PM #4
I had a similar problem a few weeks ago on my j-head. I think the issue was the filament was melting too high up the hotend and would continously clog. I initially avoided the issue by buying a second hot end . I disassembled the j-head and cleaned all the pieces by soaking them in acetone ( I was working with abs). I replaced the plastic tube inside, assembled it properly and it works fine! So if all else fails, disassemble everything and clean it all. Then follow the assembly instructions on e3d-online.com if you have an all metal hotend.
Edit: couldn't view the image so my bad if my post doesn't necessarily apply lolLast edited by paradiddle65; 12-20-2014 at 12:52 PM.
