Thread: Filament breaks off the print
12-17-2014, 11:21 AM #1
- Dec 2014
Hello everyone!
When I try to print large objects, the layers always break off each other.
The print generally also does not stick to the bed, but I could live with that. But in my case, it seems that the layers don't stick to each other. Right now I am printing with a Witbox and Cura Slicer (PLA, 210°, 0.3mm layer height, Speed first layer 20mm/s, Speed other layers 55 mm/s, no heated bet, but use of bluetape). The calibration of the bed should be all right. I already tried to print with different Filaments, but I always have the same result. Furthermore I tried to shift the print temperature, but with no result.
I also had the same Problem with my Leapfrog Creatr using Repetier and Slic3r.
Does anyone have any ideas, why that keeps Happening and how I can prevent it?
I am really desperate, since so far everyone told my that they have never seen anything like that.
Thank you very much!
Alexandra
12-17-2014, 11:48 AM #2
Cut your print speed in half and try it.
Also, is it chilly in your printing room?
12-17-2014, 11:54 AM #3
- Dec 2014
Thank you for your Input!
I can try that, but then some of my models will take more than 200 hours. That's why i wanted to Speed the prints up a Little.
We have about 22° in the room.
12-17-2014, 12:55 PM #4
The temperature sounds great. Is your printer enclosed? Is there a draft nearby?
I recommend coming up with a temperature and print speed that works well for the material as a baseline before worrying about how long it takes to print.
When we print PLA, we normally do it at 185°C and 30mm/sec, with the bed at 40°C.
Perhaps you can reduce your infill to reduce print time. Many folks print with 10-15% infill; we normally use 35%.
12-17-2014, 01:16 PM #5
- From what I see in your image is that your getting a lot of lifting from the bed, this in itself can cause layers to be misaligned and will inhibit layer delamination. After checking your machines specifications I noticed a little disclaimer saying lacquer needed to be used on the bed...
- I personally haven't had any luck printing without a heated bed. I would get lifting and had some other issues, so now I always print with a heated bed around 55-60C which keeps the air temperature around the part around 35-40C.
- My tip for this is to invest in a heated bed, this also expands your options to print with other materials.
*FYI - I print PLA at 65-100mm/s without any issues, but this was only achievable with certain filament manufactures. I overview some settings and speeds in a short filament review HERE
