Page 12 of 48 FirstFirst ... 2101112131422 ... LastLast
Results 111 to 120 of 476
  1. #111
    Super Moderator RobH2's Avatar
    Nov 2013
    Location
    Baltimore, MD
    Add RobH2 on Thingiverse
    Got my deburring tool today. It's really nice and is so much better than the back side of an xacto.
    Bambu P1S/AMS
  2. #112
    Technologist
    Nov 2014
    Location
    Orange, CA
    Quote Originally Posted by RobH2 View Post
    Got my deburring tool today. It's really nice and is so much better than the back side of and xacto.
    A machinists best friend !
  3. #113
    Engineer-in-Training beerdart's Avatar
    Feb 2014
    Location
    CT
    First print with the Itty Bitty Nema17 Modified Magma hot Ends. . We are only using one drive as someone ordered the wrong hobbed bolts (That would be me). So far its printing nice without any setting changes. Very happy with the fit form and function thanks RobH for the 17 model and Clough for the design. still need to tidy up the wires and get the auto bed level working.
  4. #114
    Nov 2013
    Location
    Baltimore, MD
    Really good to hear. So the main body rebuild was good? Any tolerance issues?
    Bambu P1S/AMS
  5. #115
    Feb 2014
    Location
    CT
    Just discovered and issue when the motor mounts heat up the attach points sag causing the belt to loose tension. It will need to be reinforced.
  6. #116
    Nov 2013
    Location
    Baltimore, MD
    Tell me what you think will fix it. Maybe a plate with 4 holes and a center hole for for the pulley? I can put a hole in the middle for it to stick through. Maybe the arms are a bit thicker? Tell me what you need and I'll modify it.
    Bambu P1S/AMS
  7. #117
    Nov 2013
    Location
    Baltimore, MD
    This is not the prettiest model but it might do the trick. If so, I'll make it nicer later. I know it's a long print but if you think this will do it give it a go.
    It must warp a alot because the best part about 'clough42' using belts is that they don't skip unless they get really loose. Are you pushing too many amps through the motors maybe? Mine don't run very hot.
    Attached Files Attached Files
    Bambu P1S/AMS
  8. #118
    Engineer clough42's Avatar
    May 2014
    Location
    Meridian, ID
    Quote Originally Posted by beerdart View Post
    You need to reduce the motor temperature (reduce current) or add cooling to the motors. Adding more plastic to the mount is unlikely to help for long. You should have lots of torque headroom to reduce the current with those motors.
    The NEMA14 motors I specify never get hotter than about 45C with the current pot set at .3V.
  9. #119
    Nov 2013
    Location
    Baltimore, MD
    This might help you Steve.
    Turn the stepper the pots down to the very minimum, manually set an extrude (with no filament in to save materials) in gcode and start turning the pots up until the motor starts to run. All of my motors ran fine at the lowest amp setting. The torque was a bit weak though. I could stop the motor easily by holding the G2T pulley. So, I turned it's put up the tiniest bit. Now when I grabbed it, and couldn't stop it. At the very lowest pot setting that prevented me from overpowering the motor is where I set it. I did this for all my motors, not just the new extruder motors.
    Now, for me, the printer is much quieter. It was never loud, but it was sometimes noisy. Now it purrs. It appears I was overdriving all of my stepper motors even though they were set at 1/4 of the range by default. I'd say the pots are at 1/8 right now. I can also hold all of my motors with bare fingers and they don't get so hot that I have to remove my grasp. So I'm with clough42, I'm somewhere around 45-50C.
    Bambu P1S/AMS
  10. #120
    Feb 2014
    Location
    CT
    Agree the motor was very hot to the touch. I turned it down I'll do the min settings while running. Thanks for the suggestions.
