12-08-2014, 11:55 PM #1
- Jul 2014
- 7
Help!! When I press extrude I get reverse and when I press reverse I get extrude
Thanks for taking the time to look at this post.
I have a reprap which i have rebuilt and have used a new greg wade extruder. The previous extruder was one where the gear feed was on the side and it fed the filament via a tube. It never ready worked and chewed up the filament. At least now i have a positive action on the filament, but the Pronto softwaree is working in the wrong direction. Pressing extrude get reverse and pressing reverse gets the extrude action. is this a firmware problem , do I have to rewire the stepper motors. Also my x axis stepper now will only home in the wrong direction away from the optocoupler.
Any suggestions please what to do.
regards Colin
12-09-2014, 05:44 AM #2
Quick fix, reverse the wires on the stepper motor. In some software, there is a setting to reverse the direction on the stepper motor, nut I usually just flip the connector on the motherboard.
12-09-2014, 02:04 PM #3
- 462
Please make sure your printer is turned off before you do this, or you risk frying the stepper driver.
12-10-2014, 12:17 AM #4
- Jul 2014
- 7
many thanks for the help
Resin has changed after...
