Results 111 to 120 of 152
11-28-2014, 09:07 AM #111
http://3dprint.com/27071/stainless-steel-iron-filament/ and other metallic filaments
11-28-2014, 03:46 PM #112
- Nov 2014
- 14
Flexible filament
11-30-2014, 06:35 AM #113
- Nov 2014
- 16
Cement filament
12-01-2014, 02:33 PM #114
- Dec 2014
- 32
I find the electric conducting filament really cool, but I think it can be greatly improved. Also, bio-friendly and biodegradable materials should play a bigger roll in the filament selection.
12-03-2014, 05:15 PM #115
- Nov 2014
- 35
super strength filaments with strong layer bonding.
Perhaps also an hybrid dual epoxy filament for dual extruder printers. Basically a ABS/Nylon other plastic laced with 1 half of an epoxy bond. 1 head would lay down 1 layer and the other the next, with the strength of a plastic along the length of the extrusion
and the epoxy bonding between the layers
12-05-2014, 11:08 AM #116
Q: What new material do you think the filament market isn't providing, or isn't providing well?
A: Conductive filaments. They are slowly coming into the market, but they aren't quite as effective as they could be. Although there is a filament that has caught my attention in this category. The filament on kickstarter called 'F-Electric' looks very promising.
12-09-2014, 12:26 PM #117
- Dec 2014
- 44
A non-conductive silicon iron as used in electric motors to hold the wire coils in place and a copper that would actually conduct well to make windings. A printed motor core would need to then be dipped in enamel and baked for insulation to prevent the windings from shorting out.
Actually it would be a core for a wind generator not a motor, and magnets installed on the armature so when spun the coils produce electric form the magnetic flux as the magnets pass by.
To be able to print such a thing would be fantastic, and with a 3 extrusion head and the correct filaments it should be possible one day. A good insulation filament to eliminate the need to dip and bake in enamel would be great also.
12-09-2014, 10:39 PM #118
Conductive material and carbon fiber are not being provided well in the market
12-11-2014, 12:44 AM #119
- Dec 2014
- 31
I'd like to see more thermochromic filament.
12-11-2014, 02:23 AM #120
- Dec 2014
- Finland
- 26
I would like to see more filaments with metal like capabilities and more transparent glass like materials.
