Results 1 to 10 of 23
Thread: How would you draw this?
11-21-2014, 12:37 PM #1
- Burnley, UK
- 1,662
And
What would you use to draw it?
I was thinking about what to use for drive belts and have tried string, bowden cable, toothed belts and screws but I thought that this:
http://www.ebay.co.uk/itm/2309588040...%3AMEBIDX%3AIT
would do the job really well and extremely cheaply.
I bought some and it is easily strong enough to shovel a head and carriage about so I now need to print some pulleys for it which is where my problems start.
I have to have a circumference that is an integer number of pitches, the balls are around 2.3 mm, the rod is 1mm so the pitch is 3.3mm or so. On the face of it it is a trivial problem.
I thought of setting up a great big spread sheet for all possible diameters but the arithmetic is not too easy.
Screenshot from 2014-11-21 18:28:27.jpg
I think there should be an easy way in Openscad but I am not familiar enough to use it. That picture is done in Freecad but it is less than ideal and involves loads of working out for each repeat.
11-21-2014, 12:54 PM #2
- Mar 2014
- 223
No idea about how to do that in Openscad, and a bit dubious over the idea of using that for a drive, in my experience the balls have a little play in those things. On the other hand it would work on a steampunk themed printer.
11-21-2014, 01:01 PM #3
- Burnley, UK
- 1,662
It's a chain, all chains have play until they are under tension. It takes a lot to snap it, I think more than the narrow toothed belts.
11-26-2014, 07:06 PM #4
look at http://www.123dapp.com/design its easy to use and free
11-26-2014, 08:58 PM #5
Just a cautionary word before you spend too much time designing a pulley.
Have you examined the accuracy of movement of the extruder you would expect by using this ball link chain and compared that the the accuracy against the expected accuracy of a belt or threaded screw system?
I'm not poo-pooing the experience gained through the design and drawing process, but you might be designing something that does not result in sufficiently accurate movement for good prints.
Old Man Emu
11-26-2014, 09:28 PM #6
- Burnley, UK
- 1,662
Well I can't test it until I've drawn and printed some pulleys.
I can't see any reason why it should be any less accurate than any other system unless I am missing something. If you have anything specific that may make it suffer then please elucidate.
I don't really have a use for it anyway, just messing.
11-27-2014, 12:54 AM #7
Ah well! In that case, go for it. It will be a good exercise.
I agree that on first glance, it should be accurate enough, but I'd do the calculations.
I have a similar device which rolls a blind up and down at my front door. I was going to pull it down and photograph it, but the blind is inside the house and that's not my territory. I'll have to get approval from the wife to play with it.
OMELast edited by Roxy; 11-27-2014 at 05:59 PM. Reason: Fix Quote
11-27-2014, 05:55 AM #8
- Burnley, UK
- 1,662
11-27-2014, 03:32 PM #9
Funny about that. She was born in Bedford, raised near Burnham-on-Crouch, so she started off like yours. Must've of been the mellowing under the Southern Sun that changed things.
OME
11-27-2014, 04:13 PM #10
- 462
I have built a polargraph, which uses this very mechanism to move a pen holder around on a vertical drawing surface (check it out - it's extremely cool) http://www.polargraph.co.uk/.
Handily, there is an openscad design for a parametric ball pulley, specificallly designed for use with stepper motors, on thingiverse here: http://www.thingiverse.com/thing:12403
My experience using these is that accuracy suffers as the engineering tolerances on the ball chain are not that great. YMMV, but it's worth giving it a go.
My 3D Norn Emissary print
09-13-2024, 02:28 AM in 3D Printing Gallery
