Thread: Metal printers for consumers
11-20-2014, 03:00 PM #1
- Nov 2014
Are there consumer 3D-printers that are able to use other materials than plastics?
11-20-2014, 04:01 PM #2
- Oakland, CA
- 935
There are some that are fitted with extruders, so you can print in various pastes and clays. See the Hyrel, for instance: http://www.hyrel3d.com/
Andrew Werby
www.computersculpture.com
11-26-2014, 11:28 AM #3
The amount of filaments being available nowadays for simple home printers like Makerbot and Ultimaker is quite astonishing, check out for example the Bronzefil filament which is metal-infused plastic. After some polishing it looks and feels like metal. Another interesting filament may be PORO-LAY, it is porous and after soaking will become elastic and flexible. It can be infused with liquids to give it different properties - maybe you want to make it conductive like metal?
Resin has changed after...
