Results 221 to 230 of 347
11-16-2014, 08:11 PM #221
- Nov 2014
- What is the most interesting thing you have seen done with a 3D printer or 3D printing technology?
A working gear ring
- If you could build your dream 3D printer, what would it include and what would it do? Let your imagination run wild!
Scan a broken object, "fix" it in modeling software and print directly onto the object to repair it
11-17-2014, 07:16 AM #222
- 3D Printer Tellus
- 83
Lord of the 3D pRinterz
The ability to use a tool to create a tool without help of another tool is unbelievable a few years ago. How will the future look like when we can replicate bio and mass in an instant?
A scanner, a material feeder for different material, some easy buttons, a way to adjust print size and full color painting directly or after print. Basically a 3D printer that is exactly like todays 2d multi printer, but with adjustable sizes and option to input different material.
11-17-2014, 08:51 AM #223
- Nov 2014
- Virginia
Enter to win a 3D Printer Challenge!
The most interesting items I have seen done, to date, with a 3D printer and/ or 3D printing technology include the following:
1) 3D printed houses
http://www.archdaily.com/543518/chin...rinted-houses/ It was a culmination of 12-years in the making to design and build a prototype 3D printer large enough to handle the production needs of a house. This technology will only become more widespread in the future, to keep the cost of construction down, in terms of labor and materials.
2) Princeton's replacement ears using material from cows
http://mashable.com/2013/05/24/3d-pr...ear-princeton/ Some speculation in the market says this technology of "digital fabrication" will be ready in as little as three-years.
However, some at MIT feel that 20-years is a closer expectation:
http://www.3dprinter.net/3d-printers...s-for-20-years
3) Research and Development on constructing replacement bones and tissue for humans, or casting devices to help heal bones and tissue when damaged.
http://gizmodo.com/how-doctors-are-p...ood-1474983505
http://www.telegraph.co.uk/health/he...nt-faster.html
http://www.businessinsider.com/3d-pr...t-bones-2014-8
4) 3D printed metal components
http://3dprinting.com/materials/meta...rinting-metal/
http://www.manufacturing.net/blogs/2...ing-with-metal
http://www.appropedia.org/Open-source_metal_3-D_printer I happily support the research and development at my Alma-mater.
The next step in the 3D printing/ digital fabrication industry will be a culmination of both plastics and metals together. If I were to build my own 3D printer, I would design it around the concept of composite design; utilizing the full potential of a solid metal component encased or molded together with plastics to increase the rigidity, strength, shear, tension, torsion (material durability), while at the same time reducing the cost of traditional solid-metal parts. The construction and manufacturing arenas could both benefit for an increased presence of composite production for the loads we traditionally place on objects in real life.
The industry that will benefit from the composite 3D market will be the patent industry. Every day people have so many thoughtful designs that are not always brought to fruition. For some, imagination is all that is needed to bring something to life. Others need to feel/ touch and improve upon the process(es). Nonetheless, 3D printers make this possible; they work in the manner humans think - that is what is mostly important.
Thank you for reading my post!
11-17-2014, 03:49 PM #224
- Nov 2014
- 46
11-17-2014, 09:56 PM #225
- Nov 2014
Most interesting thing on a 3d printer... Pieces for artificial limb.
dream 3d printer... Would have replacement multiple multifunction heads for additive (3d printing) and subtractive (machining).
11-19-2014, 02:50 PM #226
- Nov 2014
The 3d printing of tissue is awesome and super important to this world. I look forward to seeing more 3d printed organs.
I've read about a molecular printer than can basically create anything, I would want that. I would also have it come with a build in construction robot that can do the assembly for bigger pieces.
11-19-2014, 05:29 PM #227
- Nov 2014
Entry
-ASpeer275 Entry
1.What is the most interesting thing you have seen done with a 3D printer or 3D printing technology?
- I had a co-op over the summer in 2014 and got a tour of the GE Aviation additive manufacturing facility. The most interesting thing I saw and learned while I was there is that they were printing many different types of metal and actually using metal printed parts in and new engine that was being produced. To think 3D printed parts help fly people all over the world is just mind blowing.
2.If you could build your dream 3D printer, what would it include and what would it do? Let your imagination run wild!
-My dream printer would be a printer milling machining combo. i don't remember what it was called but i saw a printer that would print metal, then mill it to spec halfway through the build. this would make even milling the most intricate parts a 100% easier. That's the kind of printer i would want.Last edited by Aspeer275; 11-19-2014 at 05:38 PM.
11-20-2014, 08:23 PM #228
- Nov 2014
- SLC Utah
- 28
I agree to the rules.
The making of affordable and custom fit prostheses.
Scanning.
Print in aluminum.
Dual print heads.
The ability to print in plastic and mix colors at the print head for a fully colored part.
Heated chamber for print stability.
Ability to blow a jet of air at the tip of the extruder to freeze the plastic.
Laser cutting.
Milling.Last edited by JediJosh; 12-28-2014 at 12:07 PM.
11-21-2014, 01:03 PM #229
- Nov 2014
my answers
What is the most interesting thing you have seen done with a 3D printer or 3D printing technology?i
I have seen amazing replicas of musical instruments and cars done.
I would love to see functional items like phones and cameras that actually operate
11-21-2014, 05:03 PM #230
- Nov 2014
In-place 3D printing and adjustment of libs for mine amputees.
A print head that accepts can combine both plastic and metal, so that circuits can be embedded in the structure.
