Results 1 to 10 of 13
Thread: Levelling the plastic bed arms?
11-16-2014, 04:14 PM #1
- Sep 2014
- 54
Is it possible to level the build plate arms at all?
Reason being my right one appears to be way out, meaning when levelling the build plate I am right at the limit of the level screw threads on the left hand side (had the knob come off a couple of times as a result) to bring it nice and flat.
I had a quick look but can't really see how it can be done - happy to take apart the printer to get at it, just don't want to mess it all up by playing if it won't gain me anything.
Example - you can see how much I have to adjust the left hand side to bring the bed up to compensate for the right hand plastic arm being that much higher set at the back. You can also see the front wooden plate is raked up to the right. The plastic arm at the right on the guide rail is visibly higher.
Its 3.5mm difference in height from left to right.
