Thread: Help with printing a 3D model
11-11-2014, 08:15 PM #1
- Nov 2014
Hi there,
First post here. Just wondering if anyone can help me with an issue I am having with a model I have created. I have a MakerBot Replicator 2.
I designed the model in Maya then exported it as an STL file but when I try and print it only parts of it appear - see image:
https://mega.co.nz/#!I8s2gKbZ!HzegXynpe__hvZOQmfrHTZf86qggy99dvVD0Cg7ZNNQ
In the image panels 1 – 3 show the model I designed in Maya, panel 4 shows the resulting STL file opened in the MakerWare application, and panel 5 shows what I ended up with.
Has anybody come across this kind of problem before? For some reason only a part of the model is being printed and if you look closely you can see the hole I made in the pyramid shaped model has been printed as a solid tube (like it's inversed or something?)
Any help would be appreciated ; )
11-11-2014, 09:28 PM #2
- Aug 2014
- Montreal, Quebec
- 576
Else than the poor retraction settings, it seems your printer ignore and skip most of the work.
You sure your mesh is manifold?
11-11-2014, 10:42 PM #3
- Nov 2014
OK thanks, I'll check the model tonight in Maya for any problems.
btw: Sorry but I couldn't attach the image here and the URL option didn't work either, so I had to upload the image - maybe because I'm at work and there may be some restrictions.
11-12-2014, 02:56 PM #4
- 462
Run it through the cloud repair service.
