Results 1 to 10 of 21
11-09-2014, 05:15 PM #15
Most likely, you are not compiling and rendering the design with the new information. OpenScad (as a convenience to you) will do a best guess rendering of the source code to show you what it thinks it will generate. But, the design is not compiled and you are not ready to export the information into a .STL file yet.
Up on the Menu Bar of OpenScad, Do a Design / Compile & Render. Then export the generated information as an .STL file. That should slice without problems.
Assuming you get the .STL to export in a fashion where your slicer can digest it, Just tweak any of the numbers at the top to get it to look exactly how you want it. Just to make the code simpler... The size of the box ignores the thickness of the walls. The size of the box goes from the center of the wall to the center of the wall. And the height includes the thickness of the bottom plate. You should be able to work around those issues to get what your want.
Good luck....
