Results 11 to 20 of 20
10-06-2014, 09:13 PM #11
yeah I have mine sitting in a box here, I do have 1 roll of 3mm filament I could use, but I would literally be rebuilding the extruder to use one roll of filament, the 3mm is so stiff!! I dont know how people work with it.
Just get a J-head or similar extruder, I buy alot of my stuff of LearCNC, they are not cheap but they are reliable, aussie stock too.
http://www.ebay.com.au/usr/learcnc?_...84.m1497.l2754
If you are going to build your own extruder, I do recommend getting a few things..
Either one of these, they are $50, pretty good deal
http://www.ebay.com.au/itm/LearCNC-M...item2c86cd764d
They also sell a hexagon, which is the one I got but it's $70 and a bit overkill, I wouldnt say its all that much better than the merlin.
You will also need a hobbed bolt
http://www.ebay.com.au/itm/LearCNC-S...item2ec92a8c50
Try and get one with the offset between 24mm and 25mm, that seems to be the standard for Geared extruders these days.
10-24-2014, 01:53 AM #12
- Sep 2014
- 13
I just got the new boards, so many different bits, no instructions of course lol. will try to look at it over the weekend do you guys have any photos of which boards and connections to motors etc of your machines?
10-24-2014, 05:59 AM #13Hex3D - 3D Printing and Design http://www.hex3d.com
10-27-2014, 03:39 AM #14
- Sep 2014
- 13
Thanks, it all looks confusing to me....
11-02-2014, 07:42 AM #15
- Sep 2014
- 13
I have started putting it together my steppers have bare wire ends that screwed into a green terminal block but the ramps has pins how do you connect them? And what is d8 for ? And themostats where do they go? Cheers
11-02-2014, 09:03 AM #16
The main thing you will need is this.. These should be the same as the ones I got, they are pretty cheap and nasty but they work.
Then just simply find the best prusa ramps tutorial you can find that speaks in your language, some are a bit over the top, some are just simple enough to follow without too much messing around.
And this is your wiring
NOTE
See the end stops in the image below have 3 wires, we are using 2 obviously. See there is Green, Orange Yellow? do not use the Yellow!
You only are using the 2 connections toward the edge of the board, the green and orange. This is important for zappy zappy puff of smoke reasons.
Here is a good tutorial
http://www.danielhansen.net/2014/05/reprap-3d-printer-prusa-i3-build-log.html
You will need to also make sure the Z axis doesnt move too fast or the threaded rods will whirr awayHex3D - 3D Printing and Design http://www.hex3d.com
11-07-2014, 09:40 PM #17
- Sep 2014
- 13
11-15-2014, 04:34 AM #18
- Sep 2014
- 13
I have wired it, but it has on the arduino board a socket for a power adaptor, does it need this? the power suppy that came with the printer gives 12v at 20AMPS, the ramps requires 12v at 5A then 11A, how did you get around that?
Cheers
Michael.
11-20-2014, 06:20 AM #19
- Sep 2014
- 13
12-29-2014, 02:27 AM #20
- Sep 2014
- 13
Hey guys, I have it all wired, but nothing no movement I don't think its synced properly to pc, can you still use repetier host?
can you use the board without pc to move axises?
cheers
mike
Completely new to 3d printing and...
06-13-2025, 01:52 PM in General 3D Printing Discussion
