Results 1 to 10 of 12
Thread: Good speeds?
11-07-2014, 07:20 AM #1
- 441
Good speeds?
What are the speed's you normally run on making your prints? Low, medium, and higher quality print speeds. I just started using a Raft to get things to stick and warp less. Which is working great, but the raft's are starting to leave a residue left on my build plate I cant seem to get off. I'm thinking I will need to change the tape soon. But yeah, just curious if I'm printing too fast. I'd say the normal I have been using is Extrude 70 mm/s and travel 100 mm/s
11-07-2014, 07:23 AM #2
- 93
hi, what material you printing with abs, pla, pva, nylon etc
im curently using pla, my settings are as follows
headed bed at 60
nozzle at 195/200
extrude at 40
travel at 70
this is my settings for all qualitys
11-07-2014, 07:38 AM #3
- 441
Ah sorry, I'm stuck using only ABS until Payday :P So if you extrude at 40, maybe me using 70 is tad too fast? I also use the nozzle at 235, bed at 115.
11-07-2014, 08:09 AM #4
I was stuck with ABS for long time, so it's all I used for at least the first 6 months I had my machine...
With ABS on the Flashforge, running at 230c and HB at 110c, the following seem to be pretty standard for me..
Printing at 0.3mm layer height - 70ms feed, 120ms travel
Printing at 0.2mm layer height - 60ms feed, 110ms travel
Printing at 0.1mm layer height - 50ms feed, 90ms travel.
Re: changing tape, its pretty easy, I use a credit card to smooth out any air bubbles as I lay it down.Hex3D - 3D Printing and Design http://www.hex3d.com
11-07-2014, 09:08 AM #5
- 441
Ok so I'm not too far off from my settings then. I'm currently printing something bigger at .2mm layer height, 70ms feed, 100 travel. Will see how that turns out when I get home from work.
I did buy a nice size roll of tape with my machine ($45 >.<) Should have got it off FF website instead. What about fill %, what is your "default" fill for things you make usually. I just made it 50% for this thing I'm printing now. 2 Shells, it seem's that is about the normal for shells. Does more shells = thicker product?Last edited by Bassna; 11-07-2014 at 09:16 AM.
11-07-2014, 10:48 AM #6
I generally print with one stepper removed and almost always at .2mm layer height. I am never successful at printing .3mm layers and they always look like wicker basket crap anyway.
My standard speed with S3D is 6000mm/m feedrate and 7200 travel. This equates to 100mm/s feed rate and 120 travel. First layer is at 60% speed.
11-07-2014, 11:47 AM #7
- 441
11-07-2014, 12:29 PM #8
Yes, it is in the xml file or use profitweak.
11-07-2014, 12:45 PM #9
Actually now that I think of it, the settings are held in Javascript. These aren't directly editable in Makerware but with Profitweak you can customize profiles.
I really recommend spending the $140 for Simplify3d. Things are just laid out in a logical manner and if you are printing more than one object you can set a custom extrusion profile for each. Maybe one model needs support and the other one doesn't. Simplify3d handles this. It is incredibly fast. For things that take up to a minute to slice/process in Makerware, these take seconds or less in Simplfy3d.
11-07-2014, 01:13 PM #10
- 441
