Thread: Delamination, again.
11-04-2014, 09:05 AM #1
Occasionally, when I print something like a taller box with thinner sides, like a pull out drawer or such, I get a couple spots that are starting to delaminate. I have the bed calibrated pretty well (within spec), so I don't think it's that. I'm using the infamous XYZ Davinci 1 with ABS, so I have practically no control (yet) over temps or such. What I do have is layer height and speed (normal, fast or slow). I'm thinking if I could, a slightly higher temp on the extruder would make the plastic stick better. But since that isn't an option, my next guess is thinner layers at higher speed, so it has a better chance to stick. Is this a decent logic train, or am I nuts?
11-04-2014, 03:18 PM #2
I suggest slowing down the print speed.
I would also suggest upping the temperature a little - for those for whom this is possible.
11-05-2014, 05:24 AM #3
Hmm, it's abs so the main issue is shrinkage.
Try it with pla which doesn't shrink anywhere near as much.
And yep slower printing should work too :-)
11-05-2014, 07:08 AM #4
Ok.... Can't adjust Temperature, and can't do PLA.
My thought process was that at a higher speed, the previous layer would have less time to cool off, and as these have been fairly sizable builds, any one particular location would have a lot of time to cool down.
I'll have to do a couple test builds to see. I will try both high and slow speed.Last edited by Marm; 11-05-2014 at 07:21 AM.
