Results 1 to 10 of 172
10-30-2014, 04:30 PM #1
Saving G29 Bed Level Correction Matrix to EEPROM
Several people have expressed an interest in not having to perform a G29 Auto Bed Leveling command prior to each print. This post has the instructions to do that. However, it has not been tested yet. My printer's power supply died and it will be a while until I can replace it. The changes and theory are fairly simple, but with that said, when this many trivial changes get made, usually something doesn't work right. If you proceed with that warning and run into a problem, just make a post detailing what is wrong and I'm pretty sure we can get the problem fixed.
The theory is simple. The EEPROM (if enabled in Marlin's Configuration.h file) can save many settings that override the default settings. The changes we will make will stop the G28 homing command from resetting the Bed Level Correction Matrix. Instead, we will only do that when a G29 command is issued. Once this is accomplished, we just need to add a small amount of support to the EEPROM routines to make them smart enough to save and restore this matrix besides all of the other values they already save and restore. And of course, we add some code so the matrix can be printed out also.
To use the code, the user would first issue a M502 (Restore Default Settings) command followed by a M500 (Save Current Settings to EEPROM). This is necessary to do once because the format of the data stored in the EEPROM is going to change. By doing a M502 followed by a M500 command we are forcing the EEPROM to conform to the new data format which includes space for the Bed Level Correction matrix. Failure to do this is going to result in your printer restoring all kinds of bad values from EEPROM into important variables that it uses to behave in a sane and rational way.
Once the EEPROM is made aware of the new configuration, you need to issue a G28 followed by a suitable G29 command and if the values work as expected, an M500 command. From then on, you will only use the G29 command if you don't see the first layer going down perfect. The M500 will store the Bed Level Correction Matrix so the next time the Marlin firmware initializes itself, it will grab the last saved matrix.
To make the firmware changes do the following:
In Configuration.h find:
Code:#define ENABLE_AUTO_BED_LEVELING // Delete the comment to enable (remove // at the start of the line) #define Z_PROBE_REPEATABILITY_TEST // If not commented out, Z-Probe Repeatability test will be included if Auto Bed Leveling is Enabled.
Code:#define ENABLE_AUTO_BED_LEVELING // Delete the comment to enable (remove // at the start of the line) #define Z_PROBE_REPEATABILITY_TEST // If not commented out, Z-Probe Repeatability test will be included if Auto Bed Leveling is Enabled. #define SAVE_G29_CORRECTION_MATRIX // if not commented out and the EEPROM is used to save settings, the G29 information will also be saved.
Code:case 28: //G28 Home all Axis one at a time #ifdef ENABLE_AUTO_BED_LEVELING plan_bed_level_matrix.set_to_identity(); //Reset the plane ("erase" all leveling data) #endif //ENABLE_AUTO_BED_LEVELING
Delete the last 3 of those lines so you only have:
Code:#ifdef ENABLE_AUTO_BED_LEVELING case 29: // G29 Detailed Z-Probe, probes the bed at 3 or more points. { #if Z_MIN_PIN == -1 #error "You must have a Z_MIN endstop in order to enable Auto Bed Leveling feature!!! Z_MIN_PIN must point to a valid hardware pin." #endif
Code:#ifdef ENABLE_AUTO_BED_LEVELING case 29: // G29 Detailed Z-Probe, probes the bed at 3 or more points. { #if Z_MIN_PIN == -1 #error "You must have a Z_MIN endstop in order to enable Auto Bed Leveling feature!!! Z_MIN_PIN must point to a valid hardware pin." #endif plan_bed_level_matrix.set_to_identity(); //Reset the plane ("erase" all leveling data)
Code:void Config_StoreSettings() { char ver[4]= "000"; int i=EEPROM_OFFSET; EEPROM_WRITE_VAR(i,ver); // invalidate data first EEPROM_WRITE_VAR(i,axis_steps_per_unit); EEPROM_WRITE_VAR(i,max_feedrate); EEPROM_WRITE_VAR(i,max_acceleration_units_per_sq_second); EEPROM_WRITE_VAR(i,acceleration);
Code:void Config_StoreSettings() { char ver[4]= "000"; int i=EEPROM_OFFSET; EEPROM_WRITE_VAR(i,ver); // invalidate data first EEPROM_WRITE_VAR(i,axis_steps_per_unit); EEPROM_WRITE_VAR(i,max_feedrate); EEPROM_WRITE_VAR(i,max_acceleration_units_per_sq_second); EEPROM_WRITE_VAR(i,acceleration); #ifdef SAVE_G29_CORRECTION_MATRIX EEPROM_WRITE_VAR(i,plan_bed_level_matrix); #endif
Code:void Config_RetrieveSettings() { int i=EEPROM_OFFSET; char stored_ver[4]; char ver[4]=EEPROM_VERSION; EEPROM_READ_VAR(i,stored_ver); //read stored version // SERIAL_ECHOLN("Version: [" << ver << "] Stored version: [" << stored_ver << "]"); if (strncmp(ver,stored_ver,3) == 0) { // version number match EEPROM_READ_VAR(i,axis_steps_per_unit); EEPROM_READ_VAR(i,max_feedrate); EEPROM_READ_VAR(i,max_acceleration_units_per_sq_second); // steps per sq second need to be updated to agree with the units per sq second (as they are what is used in the planner) reset_acceleration_rates(); EEPROM_READ_VAR(i,acceleration);
Code:void Config_RetrieveSettings() { int i=EEPROM_OFFSET; char stored_ver[4]; char ver[4]=EEPROM_VERSION; EEPROM_READ_VAR(i,stored_ver); //read stored version // SERIAL_ECHOLN("Version: [" << ver << "] Stored version: [" << stored_ver << "]"); if (strncmp(ver,stored_ver,3) == 0) { // version number match EEPROM_READ_VAR(i,axis_steps_per_unit); EEPROM_READ_VAR(i,max_feedrate); EEPROM_READ_VAR(i,max_acceleration_units_per_sq_second); // steps per sq second need to be updated to agree with the units per sq second (as they are what is used in the planner) reset_acceleration_rates(); EEPROM_READ_VAR(i,acceleration); #ifdef SAVE_G29_CORRECTION_MATRIX EEPROM_READ_VAR(i,plan_bed_level_matrix); #endif
Code:void Config_ResetDefault() { float tmp1[]=DEFAULT_AXIS_STEPS_PER_UNIT; float tmp2[]=DEFAULT_MAX_FEEDRATE; long tmp3[]=DEFAULT_MAX_ACCELERATION;
Code:void Config_ResetDefault() { float tmp1[]=DEFAULT_AXIS_STEPS_PER_UNIT; float tmp2[]=DEFAULT_MAX_FEEDRATE; long tmp3[]=DEFAULT_MAX_ACCELERATION; #ifdef SAVE_G29_CORRECTION_MATRIX plan_bed_level_matrix.set_to_identity(); #endif
Code:void Config_PrintSettings() { // Always have this function, even with EEPROM_SETTINGS disabled, the current values will be shown SERIAL_ECHO_START; SERIAL_ECHOLNPGM("Steps per unit:"); SERIAL_ECHO_START; SERIAL_ECHOPAIR(" M92 X",axis_steps_per_unit[0]); SERIAL_ECHOPAIR(" Y",axis_steps_per_unit[1]); SERIAL_ECHOPAIR(" Z",axis_steps_per_unit[2]); SERIAL_ECHOPAIR(" E",axis_steps_per_unit[3]); SERIAL_ECHOLN("");
Code:void Config_PrintSettings() { // Always have this function, even with EEPROM_SETTINGS disabled, the current values will be shown SERIAL_ECHO_START; SERIAL_ECHOLNPGM("Steps per unit:"); SERIAL_ECHO_START; SERIAL_ECHOPAIR(" M92 X",axis_steps_per_unit[0]); SERIAL_ECHOPAIR(" Y",axis_steps_per_unit[1]); SERIAL_ECHOPAIR(" Z",axis_steps_per_unit[2]); SERIAL_ECHOPAIR(" E",axis_steps_per_unit[3]); SERIAL_ECHOLN(""); #ifdef SAVE_G29_CORRECTION_MATRIX SERIAL_ECHO_START; plan_bed_level_matrix.debug("\n\nBed Level Correction Matrix:"); SERIAL_ECHOLN(""); #endif
Last edited by Roxy; 11-01-2014 at 08:39 AM. Reason: Allow Configuration.h to select whether correction matrix is saved.
10-30-2014, 04:34 PM #2
I have printed omitting the G29 on the kossel, and to be honest for the few seconds it takes to perform the point check, I think I'll stick with it. I remove the glass plate alot so saving the g29 codes or re-using them might be bad for me on the kossel.
10-30-2014, 04:44 PM #3
10-30-2014, 06:29 PM #4
- Aug 2014
- 627
See, I just ran into an instance (prior I thought the same way you do) where I need to do this because if I want to multicolor print using a single extruder with the old code you just can't
Thank you so much and I will try this in a few days as Halloween is here and I am busy busy with fixing an ancient mechanical skeleton butler/decorations and doing family things.
10-31-2014, 10:27 PM #5
- Jul 2014
- Eastern Colorado
- 536
Now that we have this mod to save the G29 matrix for an entire print session (or longer), it is no longer necessary to add a G29 to the start gcode when slicing. However, those of us who run our printers standalone, we need another way of running the G29 when we change a setting or a glass plate. I believe that many who run their printer standalone have an LCD display on their printer. Here's what I did to add G29 to the LCD menu:
In ultralcd.cpp, find MENU_ITEM(gcode, MSG_AUTO_HOME, PSTR("G28"));
Just after it, add MENU_ITEM(gcode, MSG_BED_LEVEL, PSTR("G29 n5"));
In language.h, find #define MSG_ENDSTOP_ABORT "Endstop abort"
Just after it, add #define MSG_BED_LEVEL "G29 Bed Level"
Roxy, I ran into an error adding your code:
ConfigurationStore.cpp: In function ‘void Config_PrintSettings()’:
ConfigurationStore.cpp:129:65: error: void value not ignored as it ought to be
^ (this caret should be under the closing parenthesis after "Matrix")
That is the only error. Commenting out only the added code block from Config_PrintSettings let it compile cleanly.Last edited by AbuMaia; 10-31-2014 at 10:51 PM.
10-31-2014, 11:20 PM #6
- Jul 2014
- Eastern Colorado
- 536
I've made some changes in case someone decides to add this code to Marlin, but not enable it:
#ifndef SAVE_G29_CORRECTION_MATRIX
#endif
#if Z_MIN_PIN == -1
#endif
#endif
This way G28's original function of erasing the matrix is retained while the code is disabled, and then switched to G29 when it is enabled.
11-01-2014, 01:13 AM #7
- Aug 2014
- 627
No, NO, N O!!! This just means in a case like mine because I can tell you that today my matrix will look like A and tomorrow the matrix will look like C and the next day B=A+/-C so in my case I would never ever just use the same matrix all of the time. One print then another (as in my example) I might (I have not tried it yet but theoretically it should be fine) but never from one day, or even hour, to the next. Basically if the bed has had a chance to cool completely down, as well as the entire printer, forget using a previous matrix.
11-01-2014, 08:43 AM #8
It's fixed now. Somehow during the Cut & Paste I didn't get the very last character of the line (which was a semi-colon. The compiler knows it is missing a semi-colon, can't it just put it in there for me???
Any way, if you go add the semi-colon it should compile clean and let you print out the Bed Level Correction Matrix. I'm not sure how the output is going to look because I can't run any of this code yet to test it.
AbuMaia, does the code behave as expected and do what people wanted? Can you add the semi-colon and invoke the EEPROM Print so we can check if the matrix prints OK ?Last edited by Roxy; 11-01-2014 at 02:08 PM.
11-01-2014, 08:45 AM #9
Yeah, I was kind of torn which way to go. Doing what you did preserves the original behavior which has merit. It might be worth a quick discussion to decide if those extra #ifdef's should be added to the first post or not. Personally... I think the correction matrix should start off at Unity and not be affected by the G28. But there is so much legacy in place now that it isn't good to change things for no reason. I decided to make the changes as minimalistic as possible (which meant not adding the extra pre-processor commands). However, with that said, nobody is going to be typing that stuff in anyway. They are going to Cut & Paste it into their source, so there isn't any extra pain involved.
So should we alter the original post? If we do, and SAVE_G29_CORRECTION_MATRIX is not defined, everything will function the same as it used to behave.Last edited by Roxy; 11-01-2014 at 08:50 AM.
11-01-2014, 08:52 AM #10
