Results 1 to 10 of 35
10-28-2014, 07:47 AM #4
I've added a file to show you exactly what I get on my prints (this is 0.15[mm] layer height) though, much worse on 0.1[mm]!)
Ok! that sounds like a very plausible cause too!
But.. I don't know if I'm using micro-stepping, and I do not know whether my stepper is cheap or not (willing to buy new ones though!)
Do you perhaps know what I need to look for in a stepper motor (for Flashforge Creator)?
And do you think this is for feeding or for X & Y too?
I got lost in your math... completely.
But I will measure my oscillations (which look quite similar to yours!) as soon as I get home. The only difference being that I use a 0.4[mm] nozzle.
But in conclusion: I need to scratch all my thoughts and focus on the stepper motors that feed the material? Better motors = more consistent feeding, or can I change the firmware somehow regarding this?
Thanks for the help btw, really appreciate it!
And yes, larger layer height means more extrusion so the variations between steps are much less noticeable. (at least, that is my observation from all this)
