Results 11 to 20 of 40
10-18-2014, 02:39 AM #11
- Burnley, UK
- 1,662
10-18-2014, 08:49 PM #12
Have you checked this thread? It details how to fix it on the FF original and I believe someone corrected the thread for the Creator Pro or X
http://3dprintboard.com/showthread.p...-across-printsHex3D - 3D Printing and Design http://www.hex3d.com
10-19-2014, 06:31 AM #13
mines the straight creator (I think lol)
I did look at that screw and then at the metal noizzle which would seem to be bang up tight against the thing above it.
Having problems with the white reprapper pla at the moment . It either needs to be printed at temps above 220 - or it's utter shite.
Either way I still think the right nozzle is buggered.
So where can I get spares ?
10-19-2014, 07:57 PM #14
I would get a nozzle cleaner kit before I bought a new nozzle, with the exception of some very very bad black filament I got, there has been no blockage a small piece of metal wire didn't fix.
I keep them on hand at all times now.. They are just a fine metal wire, basically a guitar string that's small enough to poke up through the nozzle hole.
PLA blocks my extruders, it happens. ABS never did because I guess it's always at the high heat. With my prusa, I literally unblock the nozzle before each print because the PLA went so crap inside.Hex3D - 3D Printing and Design http://www.hex3d.com
10-20-2014, 06:26 AM #15
I have cleaned the nozzle a few times. Having had extrusion issues with this pla at 215, I'm thinking I just wasn't runnig it hot enough. And no I didn't try it with any other pla before I pulled it. Didn't have any more time to buger about as I had someone coming and needed to get it working.
So I'm pretty sure the left nozzle is worn short. And there's no actual problem with the head setup.
I need spare nozzles.
Where can I get spare nozzles, other than flashforge usa. ????????????????????????????????????????????????
10-20-2014, 06:30 AM #16
- Burnley, UK
- 1,662
I can't understand your problem getting nozzles. I just bought 10 for a few $ and bought heat tubes the same way. Is yours different from mine or what?
10-20-2014, 06:44 AM #17
Aliexpress has them: http://www.aliexpress.com/store/prod...981661391.html
10-20-2014, 07:11 AM #18
Do note that these look like the 'original' ones.
(see this link: http://www.flashforge-usa.com/shop/nozzle.html )
I think I have the 'updated' ones on my printers.. but not sure.
10-20-2014, 10:00 AM #19
Be careful on the nozzles, they aren't all compatible from brand to brand. Different thread sizes are used.
10-20-2014, 10:05 AM #20
