Results 431 to 440 of 757
10-14-2014, 09:58 AM #431
I didn't know enough to get a Python script running on Slic3r, so I just made a quick and dirty C program to do it. If 9999.9 mm isn't enough, it is Open Source! The user can change it to 99999999.9 mm !
Anybody that doesn't want to compile, can just use the executable. Compiling isn't a big deal to (or for) me. I like my C compiler!
I could have updated in place by opening the file for read / write, but the problem is the G29 line grows in size when you add the extra parameters. So, it is more difficult than just inserting the extra information. Hence... the generation of a temporary file. Its only a few lines of code to rewrite the file once you know what you are going to do to it, so that is the path I went.
But back to your point.... If you can get your script to work with Slic3r, it probably would be best to just have one solution that works for everything. Do you care to give it a try?
10-14-2014, 10:33 AM #432
- Sep 2014
- 13
Of course, it works and you can try it !
1-just download the file from github : https://github.com/syl-20/Marlin/blo...inting_area.pl
2-add the path to the post processing script in your slic3r config ("print settings" tab / "output options" section)
3-add your custom start gcode ("printer settings" tab / "custom gcode" section) like this one : G29 L[G29XMIN] F[G29YMIN] R[G29XMAX] B[G29YMAX] n4
Thats all !
Before the script, the gcode is :
Code:... G1 Z5 F5000 ; lift nozzle G29 L[G29XMIN] F[G29YMIN] R[G29XMAX] B[G29YMAX] n4 M109 S200 ; wait for temperature to be reached ...
Code:... G1 Z5 F5000 ; lift nozzle G29 L73.340 F73.340 R126.660 B126.660 n4 M109 S200 ; wait for temperature to be reached ...
10-17-2014, 08:36 AM #433
- Sep 2014
- 13
Hi Roxy,
So I test my perl script with the fork of beckdac ; it is perfect ! The probe is restricted to the printing area, the repetability test is OK, .... Congrats !
So I fork the fork of beckdac and integrated my script + the last commits of ErikZalm.
Everything is here : https://github.com/syl-20/Marlin
Thanks a lot
10-18-2014, 11:48 AM #434
- Aug 2014
- 8
I havn't been able to get that Perl script to work. (slic3r throws up errors about "Cant do inplace edit without backup") What version of Perl are you using?
10-18-2014, 06:48 PM #435
Having some issues here, would greatly appreciate any help.
http://3dprintboard.com/showthread.p...ll=1#post31462
10-18-2014, 08:50 PM #436
Working through most of my issues I had in my other post, but wanting to fix this also.
I need my Z axis to raise before it retracts the Z probe,
I saw your post mentioning changing the code in Marlin_main.cpp
but for the life of me, I dont see what you are seeing to change. Your examples look identical to me.
10-18-2014, 09:02 PM #437
- Jul 2014
- Eastern Colorado
- 536
If you're using the Marlin MakerFarm fork from the other topic, those changes are already in your firmware, I think.
10-19-2014, 03:16 PM #438
So far, I haven't been able to get it to work either. But to be fair, I've been super busy and haven't had the time to invest in this. The whole reason I did the .EXE file was because I use Slic3r and wanted it supported. So, you might want to give that a try.
One caution.... There script version is better about parameter names because it is very clear what is being put in place. It is searching for substituting the right numbers into the [G29XMIN], [G29YMIN], [G29XMAX], [G29YMAX] items. The .EXE version just looks for a G29 and tacks on the extra information needed.
Sly20, can you take a quick look at getting your script to work with Slic3r? That would help a lot of us out.
10-20-2014, 03:04 AM #439
- Sep 2014
- 13
Hi,
On Slic3r / Linux, the script is OK as it is. Perl is installed by default.
On Slic3r / M$, you just have to :
- install perl if you do not have it (https://www.perl.org/get.html) ;
- just download this script (https://github.com/syl-20/Marlin/blo...inting_area.pl) and uncomment the line 22 (#$^I = '.bak'; for m$ only) ; I recently add this feature for M$ OS that does not support inplace streaming.
I have tested both (Debian OS and M$ XP) with success.
10-20-2014, 09:01 AM #440
- Sep 2014
- 13
Roxy,
I have some questions :
Why do I have some "+-" before some values of the topography ?
Code:--0.22982 +0.00091 +-0.17644 -0.22815 --0.00807 +-0.13478 -0.17552 +0.19074 --0.04623
In addition, I do not understand the values of this matrix ; here are the values :
Code:Bed x: 78.00 y: 71.00 z: 3.21 Bed x: 101.00 y: 71.00 z: 3.67 Bed x: 124.00 y: 71.00 z: 3.62 Bed x: 78.00 y: 97.00 z: 3.44 Bed x: 101.00 y: 97.00 z: 3.43 Bed x: 124.00 y: 97.00 z: 3.63 Bed x: 78.00 y: 123.00 z: 3.27 Bed x: 101.00 y: 123.00 z: 3.31 Bed x: 124.00 y: 123.00 z: 3.40 Eqn coefficients: a: 0.01 b: -0.00 d: 3.24 Mean of sampled points: 3.442588
-0,232588 -0,002588 -0,172588 0,227412 -0,012588 -0,132588 0,177412 0,187412 -0,042588
Some values mismatch too much with the topography given by the code ... I do not know why ?
Thanks a lotLast edited by syl20; 10-20-2014 at 09:26 AM.
