Results 11 to 20 of 36
10-07-2014, 07:21 PM #11
Hi
I have emailed you, I have sent you messages on here, and yet over a month later I have absolutely no replies.
And, when you do come and reply to the thread, you completely ignored my very very simple question and post another advertisement. I see little point spamming advertising when people who do actually contact you and want to make a purchase get no response.
This is not good business.
**Added Spam infraction.Last edited by Geoff; 10-07-2014 at 08:59 PM.
10-17-2014, 01:36 AM #12
- Sep 2014
- 27
The good news!HE3D delta 3 d printers have heating bed!
10-17-2014, 01:57 AM #13
- Sep 2014
- 27
hello everybody !
We are 3 d printer manufacturers from China,
we have high quality products and thoughtful after-sales service,
we are recruiting agents all over the world,
if you are interested, please contact me.
skpe:reprappro.cn
email:support@reprap.cn
web:http://www.reprap.cn
10-18-2014, 08:00 AM #14
what is the size, it look good, I might get one for my printer!
10-19-2014, 01:05 AM #15
- Sep 2014
- 27
Thank you very much for your reply!
Products Description:
The delta 3 d printer heating bed upgrade kits
List:
1:Heat the bed 1 PCS(Wire has good welding, welding thermal already)
2,The power of 250 w DC24V 1 PCS
3,Relay board 1 PCS
4,M3 * 30 screw 3PCS, spring 3PCS, 4PCS M3 nut
5,The M5 * 10 4 screw
10-19-2014, 01:06 AM #16
- Sep 2014
- 27
List:
3,Relay board 1 PCS
10-20-2014, 03:09 AM #17
- Sep 2014
- 27
Our heating bed heating time is 40S, it is fast, you deserve it, believe me!
10-25-2014, 04:05 AM #18
- Sep 2014
- 27
HE3D mini 3D printer, lovely!
Attention: This product is kit package ,need assemble .Thanks .
3d printer Motherboard: melzi main chip 1284 p
3d printer stepper motor A4982 chip
Output power: 24 v input AC110-220 - v
Print the most large area: 140 x140x110mm
Physical size: 260 x280x280mm
Printing material: ABS, PLA, 1.75 mm in diameter.
Building surface: PCB heating bed, aluminum mesa, in order to reduce the complexity of the assembly, to ensure parts deformation.
nozzle diameter:0.4mm (if you need 0.5mm, please left a message for us)
Precision standard: 0.1 mm
Resolution: 0.0125 mm
Construction speed: 1800 mm/min
Move speed: 1.2 mm/minute
Operation systerm support: Linux Mac windows7 or later XP
Printing software: Repetier Host or Pronterface
Deposition rate: 33 cm/hour
Movement: X and Y and Z axis low friction bushing, X, Y is linear bearing. All welded electronics and built-in microSD card slot for independent printing. Enhanced set, improve the X and Y shaft assembly is convenient Ultra-low print noise, let you print more quiet!
Contain all parts for assembly .
1, 1 pack hardware fittings
2, 5 NEMA14 stepper motors
3, heating bed 1 set of components
4, extrusion units 1 set
5, RP plastic parts 1 bag(total 42 piece. 2 metal coupling)
6, power supplier 1
7, 1 piece motherboard
Besides, we will give you 100g ABS , a set of special little tools and 1m high temperature tap as gifts . Thanks .
It is recommended that at the same time buy:
10-26-2014, 09:49 PM #19
- Sep 2014
- 27
Ok, you don't need plastic parts, $360 a set
10-29-2014, 09:38 PM #20
- Sep 2014
- 27
Delta, increased the hot bed, more perfect!
heat up quickiy!work after 40 seconds,the temperature can be heated to 120℃
Attention:if you entered website from my AD,Please be sure to say "hi jo-jo", I well thank you very much, and I will give you a surprise.Thank you very much.
06-09-2024, 02:07 PM in General 3D Printing Discussion
